Ford’s F-150 Lightning is falling behind Tesla’s Cybertruck in deepening EV crisis
owl123
Derek
Portland, ME
2023 Lightning Platinum, Model Y
I think the ER battery pack is overrated as a solution for those with range insecurity:
I think larger battery packs are overrated. Charging speed is more important (and the Lightning isn’t great there). If you’re truly road tripping, a bigger battery pack only gets you further for the first leg of the trip. And if range is cut in half during the winter, then so is the range advantage of the larger battery pack.
Right now the Silverado outpaces the Lightning in both regards, but an ER or SR Lightning with Silverado charging speeds would be a bigger upgrade than a Silverado sized battery.
StevenC56
Steven
Fresno California
2024 Lightning Lariat Avalanche, 2017 Explorer Platinum
There's nothing that's perfect enough to totally satisfy everyone's needs at this time, and who knows if and when things will evolve to do so. You have to pick your poison. So do you want the Silverado's larger battery pack? You have to pay more than the Lightning to get that. But then you have a heavier truck that is noisier, doesn't handle or ride quite as well and doesn't have as nice of an interior. I have enough patience (and lack of bladder capacity) to deal with the Lightning's range and charge speed.
Ventorum94
FL
Chev Avalanche, BMW 550i, Tesla MY, Tesla M3
Mechanical Engineer
It would seem that every size battery pack could have significantly faster DCFC, if the pack could be divided into two equal (400v architecture) modules, coupled in parallel for driving, but in series for charging (higher voltage for charging, resulting in more kW for the same acceptable level of Amps). This switching from parallel coupling to series is the magic that Silverado uses, I believe, for fast charging of that humongous battery pack.
Oafy44
Georgia
23 ford lightning
Landscape contractor
On 25 degree days I feel a lot different than today when it was 75 in Georgia. 2.5 plus today with a level and 60 lbs tires on the corners seems just fine on my lariat ER
now in a few months when GM is offering $15k off then I might be wondering.
second /3rd year model of GM will be interesting. That will be the crossroads when GM can prove their set up is formidable and Ford will be hopefully not screwing up the rollout of next generation lightning.
Erik
2023 Ford Lightning XLT SR
This is exactly it. A 33% larger battery pack, at the time I bought my XLT, I would have had to spend almost $12,000 more to get an ER, and for something that would only add value for me a few times a year, and be wasted 360+ days a year, made no sense, for me (and I logged 29k miles in my first year). If my budget was bigger, probably still wouldn’t have gotten the ER- I would rather save the $12k towards my next vehicle purchase 8-10 years down the road. Charging infrastructure is what we need (more DCFC along highways), and technology that shortens DCFC times (800v is one). A 200 kWh battery pack (Silverado, I’m looking at you) doesn’t make sense for most people’s use cases, though of course it does for some.
rdr854
Northern Virginia
Going back to the original topic at hand . . . , my felling is that the Lightning is NOT falling behind or otherwise a failure. All of the BEV pick ups have their strong suites and use cases - what ever those may be for the Paterson that bought it.
For me, the Lightning checks all the bases that I need for functionality and travel. I’ve only had range anxiety twice in 20K miles (18 months of ownership) and only once was my fault. The first was where EA pulled a charge station complex down for replacement 30 minutes before I got there and the other was two weeks ago when I decided that leaving with 80% SOC would be sufficient for a trip that I always leave with 100% SOC and come back with approx. 35% SOC.
If I was looking for a new truck, I would consider the Silverado LT EV, but think I would probably end up with the Lightning Flash or Lariat. While not perfect, I think it’s the better value. For me, the Cyber Truck is just too weird for me with the way the interior is set up and the space utilization. I will stay away from the polarizing looks.
XENOILPHOBE
DC Swamp
2024 F-150 Lightning Platinum, 2024 Tesla Model X Plaid, 2024 Model Y AWD
Retired Army
I drove the CT for the first time this past week, loved how it handled (Porsche 911 like performance), however the rest of it wasn't me. Very happy with the Lightning, now that I have worked beyond its strange quirks (Airplay mostly). I also just ignore the WAGOMETER, and drive the truck.
lipnorth
Connecticut
2023 Ford 150 Lightning Lariat
Thank you for posting what is a giant waste of time article filled with incorrect assumptions and what i can only assume are made up "testimonials". There is no connection to Tesla at all in the article except "cybertruck sold more." big deal, they sold a few thousand more units in 2024 because it was the launch, we'll see how this year plays out.
My favorite dumbass comment in the article is that Ford including the "$2000 charger" is a new thing to spur sales.
I bought my lightning in 2023 and Ford provided a Ford Charge station pro and I got rebates for the install with the truck. How is that a new promotion?
lipnorth
Connecticut
That's simply not true. The Lightning advertises a range of 230 miles, everyone on this forum demands that you never charge the battery to above 90%. Off the rip, you are at 207 miles of range. Factor in weather conditions, driving speeds, and altitude changes, the lived range is 160-180. The truth is that the manufacturers are not clear with the reality of these vehicles, and the owners are so defensive that getting clarity doesn't generally arrive until you own. And that is where the disappointment really crystallizes. simply put these trucks are not what they advertise, and the word is getting out.
You are supposed to charge to 100% from time to time and its very ok right before a long trip.
HOTAS
Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
Most every regret/complaint about the Lightning is rooted in someone who bought the standard range version, and (or) overpaid/ couldn’t afford it.
lipnorth
Connecticut
I hope the 2027 exists at all. I suspect the T3 will end up being the only pure EV truck from Ford and in the future the F-150 Lightning will become an EREV with a gas generator range extender similar to what Ram is doing.
Solid state batteries are set to be a Game Changer. Twice the capacity at 1/2 the size/weight and faster charging. Thats the next revolution. Also make it an EREV and you might have a vehicle that eliminates range anxiety.
WHPHLightning
And when your battery degrades, the first thing they'll point at is the fact that you charged to 100%.
Furthermore, it's not only the off-the-bat 10% loss, the overall volatility of the range is a huge compromise vs. expectations.
Thus, the article we are discussing.
It's not a user problem, it's a manufacturer one; we are just holding their feet to the fire.
lipnorth
Connecticut
Not to be political, but we are also lacking political leadership and vision to solve our EV problems.
If we put solar in less 1/3 of the giant parking lots in the US, we would generate enough electricity to become green energy independent. That, combined with EV chargers everywhere we could make EVs practical for almost everybody.
France is currently mandating that exact solution. I know France might be a dirty word, but its a smart solution that would solve a lot of energy problems.
WHPHLightning
I'll make your claim even cleaner; all regrets/complaints about the lightning are rooted in expectations set by the manufacturer not being met.
This strikes at the core of the issue. Owners have no problem spending what they spend if they receive what they were promised. Owners have no problem with the standard-range vehicle if it performs as promised.
The issue is, they didn't and it doesn't.
And the trope of "spend more money to solve your problem" or "complainers are broke" is honestly, quite lazy upon further inspection.
lipnorth
Connecticut
I own two EV‘s Want a lightning and the other a Kia. Both dealers have told me it is OK and recommended to charge to 100 from time to time.
