Audio/Car delayed turning off for ~10sec after turning off 'ignition'? Chime?
jrcransto
Boston
Accord Hybrid 2017
Have a '24 Flash...the audio and car stay 'on' after turning of the 'ignition' for ~5-10sec. Is there a setting to get everything to turn off when turning of the ignition?
And is the short chime/beep when you turn on/off the car indicative of anything? It does it maybe 90% of the time and can't figure out what it means.
On my 2022, audio stays on until I open a door. In the old days this was called Retained Accessory Power (RAP). Note RAP lasts about 10 minutes (or when a door opens).
The truck will chime 4 times if you press Start with the seat belt disconnected. This is the US seat belt strategy. You can change to the European seat belt strategy which waits until the vehicle is in motion to chime. You can change this with FORScan.
Open the door.
