Intelligent backup power issues/unreliable
Aminorjourney
Internet
vehicles that go
Well, what do you know?
Mine just started working again!
I noticed a few weeks back that our charger appeared to be getting something from online, but I can't see any difference in the app (unless it's a tiny revision).
System worked just fine yesterday, although I'll be honest: I didn't run it for a long time.
Sea Ranch
Wes
CA
'22 Lighting, '24 Rav4 Prime, '19 Carrera T, '23 R1250 RT, '24 Transalp
That is excellent news. After many months of frustration and almost giving up on the system, I have been very fortunate that mine has worked during the past year each time I have done a simulated outage. Having said that, the last time I did have to unplug the charger for a few minutes and then plug it back in to "kick-start" the communication.
Sea Ranch
Wes
CA
And it’s broken again.
Another blip in power this morning, along with errors 1 and 2 on the inverter this time.
That is not good. I am on my third Ford Pro Charger. This one has been working well but I did install an additional 50 amp circuit and have a ChargePoint Level 2 charger as a backup just in case it fails again.
bananaslug79
Samas
"Sparky" 2022 F-150 Lightning Lariat SR
Self employed
Two more tests today, all failures. Tried @Jim Lewis's plug in/out trick on several attempts, no joy. Charge station is green, Sparky's charge ring is white; multiple tries of unlock button>unplug cord and wait (no more than 30 seconds each time, this is a simulated outage here and I am NOT waiting longer). Still nothing.
Can't believe I'm in favor of class action here, but after a year and only 1 successful test (just after install last January) this is a non-working system for a LOT of money. @Ford Motor Company, I either want a working system with reliable and repeatable testing procedures, or kindly refund the entire cost of the system. I would prefer the former, but we're about to pay off the loan taken out to get this backup system installed. It needs to work.
Sigh...off to join the other thread
tearitupsports
Russell
Houston, TX
F-150 Lightning Lariat ER
I am not sure what you are meaning about the 30 seconds. It takes about 1 minute and 20 seconds or so from the time of the power outage until the light ring on the truck turns green. un-plugging and re-plugging would reset that timing and you need to wait another 1 minute 20 seconds.
bananaslug79
Samas
Self employed
Wow, thank you for this information. Is this 1 min 20 sec limit documented somewhere? @Ford Motor Company?
I will be more patient on my next backup test. Having reviewed some of the other threads on troubles with the HIS, I might also see what the truck screen thinks is happening next time too. Thanks
blitzlinger
WNC
'23 F150L Platinum, '18 Toyota 4Runner TRD ORP, Polaris Ranger EV
ISP Owner & Network Engineer
This is what I noticed as well. I timed it several times and it's always 70-80 seconds. At least with the current FCSP version (FW 5.0.16, SW ending with 1.5.3).
And yes, reinserting the cable will reset the timer, which I did have to do because the truck goes into sort of a sleep mode and ignores the HIS/FCSP handshake call until the cable is disconnected and plugged back in.
Jim Lewis
San Antonio, TX
On the UNLOCK trick, after pressing the UNLOCK button on the port and removing the charger head, I always wait at least 10 to 15 seconds before plugging it in again. I've sometimes waited as long as four or five minutes, and it's still worked.
After plugging the charger head into the truck port again, you'll probably be good to go if the white port LEDs don't go out in about the first 30 seconds. If they stay on, I've found that somewhere between 40 seconds to as long as two minutes after plugging the charger head back into the port, power transfer will begin (the port LEDs will turn green). But actual power transfer to the house may only occur 10 to 15 seconds after the port LEDs turn green). I haven't tested my system since the end of December. YMMV.
