Coming from a Model Y, talk me in/out of a Lightning
dww
San Antonio, TX
F150L, Tesla 3P, YP
My wife has a Y and I have a gas F150 Lariat. The lightning prices seem good right now so I'm considering pulling the trigger on a lariat lightning. Anything I should know since I'm coming from the world of Tesla?
Sounds like you are coming from gas F150. I think you’ll like it. If you were only Tesla and had only been Tesla for 5+ years then you would feel like you were going back 10 years. If you had never had a Tesla you would think the software was great and the app was amazing and would be wowed by Carplay. Most of my daily driving is in the city. I almost always take the Y. The sound system is 10x better, it has FSD, I find the seats more comfortable, the UI is better and faster, it has sentry and remote view, it’s easier to park, it uses less energy and does all but lumber runs. The Lightning gets used when we go on trips (more comfortable for more people and pets), I need to tow , do truck stuff or need 120/240 somewhere that does not have it. My only trade would be if the Cybertruck did both things better and I could have just one. It can’t. The Y is easier in town and the Lightning carries more stuff with a much larger frunk and passenger area.
Altivec
Mine does not lock on walk away. I always use the two button keypad to lock. Your PaaK works on walk away? 23 Lariat ER.
My 23 Platinum locks when I walk away. I got that feature in an update around 6 months ago. I think there was also a setting somewhere that I had to turn on.
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
no, I do the same. I was referring to needing to carry the fob. Walk away lock is available but most of us don’t have the update yet.
Altivec
I don't need to carry a fob either... I think it was the same update. Not sure why some people get updates and others don't. I am not in any special early access program either.
Hammick
Kansas City, Missouri
The Lightning is very fast, very comfortable, quiet, can haul a load of lumber, and can tow my 7000 pound boat the 20 miles I need it to.
It could tow your 7,000lb boat about 140 miles if you really need it to but you better have a charging option by the dock
Hammick
I have a '22 Lariat ER and it does not have walk away lock. It's my understanding the '24 model has walk away lock like the MachE and it's anyone's guess if our older Lightnings will get it via OTA.
Hammick
They are inconsistent. It can take 1, 2, 3 or more touches. The lower two buttons always work.
Weird. Ours works 100% of the time with one press. Are you using an iPhone? Our 14 pros and now 16 pros have never had a problem with PAAK and door button lock/unlock. Maybe delete your PAAK and re-pair.
dww
San Antonio, TX
F150L, Tesla 3P, YP
Weird. Ours works 100% of the time with one press. Are you suing an iPhone? Our 14 pros and now 16 pros have never had a problem with PAAK and door button lock/unlock. Maybe delete your PAAK and re-pair.
13 Pro. It’s 1-2 tries on unlock. If it’s more than that I’ll bring Fordpass to the front. Then it’s 1. What was annoying was when I washed the truck, if I left my phone in my pocket it would constantly be locking, unlocking, presenting, retracting the side board if was working around the doors. I found that if I put my phone in the truck it stays unlocked. I’m good with how it is now. The Tesla can miss on unlock too.
Zaptor
.......... Trophy husband
<- this truck (2022 Lariat) was our first EV ever. Then my wife got a 2023 Tesla Model Y performance. We sold the Tesla in under a year, and got her a 2023 Lightning, because it's that much better and also not nearly as... controversial these days.
Just do it, best call ever.
Cheers
Zap
JerseyMike
Allentown, NJ
2022 Ford Lightning Lariat SR, 2" pucks, P275/65/20 Nitto Recon
I own a 2019 model s and lightning. Had the model S first for a couple years (bought it used) and then bought the lightning (SR Lariat) about a year and a half ago
I also came from an ICE F150 (2019 raptor)
The lightning is much more traditional of a vehicle and bigger obviously...it is essentially identical to the ICE f150 that you have but with a bit more tech....however the lightning drives much better than the ice F150 on road...acceleration doesn't compare, ride is smoother and I even leveled mine on 34's but it still is really comfortable....the frunk adds a ton of storage. the fit and finish is great, slightly better materials than the ICE f150 in many areas
negatives:
compared to the tesla the big negatives are:
that you don't have the full tesla charging network....even with the ford adapter it only works on newer V3 and V4 chargers (which have built in adapter anyway)
also when going to tesla chargers the cable is often too short to park in just one spot and that is a pain
highway speeds impact the range much more than in the tesla (I do have a level and bigger tires so may not be as bad stock)....with the model S I routinely can drive at 80+MPH but with the lightning I usually stay around 75MPH
winter range loss is pretty much proportionate to the tesla and something I was already ready for.....you can technically (and I have) run with the cabin heat off and seat heater on and get very good winter range
JerseyMike
Allentown, NJ
negatives:
also just to mention.....after getting the lightning I was planning on selling the model S but my wife drives it now every day and we have our gas guzzling SUV mostly sitting for road trips or if we need to carpool (escalade ESV)
its a great setup and I typically trade trucks frequently but this lightning is hard to beat (other than range anxiety which I was prepared for having had a tesla)
I disagree. I have never taken the fob anywhere with me and have owned the truck for two years now. PaaK works fine.
Now you don't get the Key cards that you get with Teslas if that's what you're referring to but also don't think they are needed.
You can disagree all you want, but PaaK is not foolproof, nor is passcode. Ask those that got stuck.
FORScan can enable it.
Mine always work.
