BCM Pinout Diagram Needed
bordner42
Brendan
F-150 Lightning Pro
Id have to test and see how they function, im not with my truck and wont be near it till the weekend, but the +/- next to your headlight control might dim the switch back lights.
I think im really missing what the question in here. If was adding these aux switches and was trying to power them up I would run pin 11 on C9120 to pin 2 on C930 if i was looking for the shortest route to get the switches lit up. Maybe i need to read back through this thread and see what youre trying to do and what im missing.
Okay, I think we’re on the same page, just got sidetracked by the comment about you helping with ambient lighting.
I originally had planned the illumination cable to tie into another already present illumination cable in the overhead console. That’s illustrated on page 3 of the PDF, I changed my writing diagram on page 4 after your suggested to pin it into C2280B. So it sounds like you agree that pin 2 on C930 would make more sense than anything else.
Would you also wire in ground from C9120 to that same connector into pin 6?
JHForman812
Indiana
2022 F350
Yeah im a shortest route possible kinda person if I can be lol. I would get power and ground from there.
bordner42
Brendan
F-150 Lightning Pro
This would be connecting pins 6 and 11 from C9120 to pins 6 and 2 from C930 correct? What about pins 1/9 from C9120? Still just into the frunk area with the switch cables and connect to a spare fuse in the fuse box in the frunk?
JHForman812
Indiana
2022 F350
1/9 on C9120 go to fuse 2 on the BCM instead of trying to grab power from elsewhere, i would get an add a fuse and put it in fuse 2 and run a wire up the pillar and to the console. a lot of stuff runs on fuse 2 like the moonroof and a couple other things if i remember correctly.
bordner42
Brendan
F-150 Lightning Pro
I planned on running the switch wiring down the driver side A-pillar, so there really isn’t much difference than including it with the cable bundle in through the firewall right?
For connecting to pins 6 and 2 in connector C930, how should that be done? Haven’t done much wiring since high school engineering, so would appreciate the help!
JHForman812
Indiana
2022 F350
Ive never installed the aux switches, but wouldnt going down the passenger pillar be better? or is the BCM in a different location on the lightning?
as for making the connections for 6/2, theres tons of ways to do it. the quickest are the T taps and probably easiest. me personally, I would depin the connector cut the terminal off, put the 2 22ga wires together on a new terminal and put it back in but that is a lot of work. the other methods would be cut the wire and butt splice, or strip back the inulation and solder the 2 together. theres tons of ways to do it. id pick what youre most comfortable with, any of them will get the job done. crimping a new terminal is probably hardest, followed by solder splicing being 2nd hardest.
bordner42
Brendan
F-150 Lightning Pro
I’ve only ever seen people go the firewall grommet on the driver’s side in videos, so admittedly I haven’t even looked to see if there’s also one on the passenger side. That’s the only reason for that.
But thanks for the different ideas to connect the wiring! I haven’t gotten around to figuring out how I was going to yet, been preoccupied still getting the wiring locations sorted. Any recommendation for what wiring to use to connect from the C9120 pigtail to the relays/add-a-circuits in the frunk compartment?
JHForman812
Indiana
2022 F350
it looks like everything is 22ga, order 22ga cross link TXL wire.
bordner42
Brendan
F-150 Lightning Pro
Thanks! I’ve been struggling to figure out what gauge wire the pigtails from the connector are. It’s part number EU2Z-14S411-SA, but there’s not great information on it anywhere online.
JHForman812
Indiana
2022 F350
most stock wire in the truck is going to be tezfel, its more expensive than TXL tezfel is thinner also(22ga vs 22ga). I build my harnesses out of TXL wire its served me just fine for a long long time. if you want to spend the extra money get 22ga tezfel but TXL will work just fine.
bordner42
Brendan
F-150 Lightning Pro
I was looking into using one of these fuse/relay blocks with ACC control to control the switches. I want them to be able to be left in the on position, but only get power when the vehicle is started. The block has positive and negative connections for all 6 switches, if I were to ground the upfitter switches in the upper console what do I need to do with those?
watts/up
23 Pro SR
Not sure how far you've gotten on this but if you intend to use this fuse/relay it looks like the wiring is a bit unintuitive. Check out this comment. From the reviews it looks like the relay's +/- inputs are not really positive and negative. If I understand correctly you're really only wiring up the - inputs to the upfitter switches. Does that sound correct to you?
Edit: this comment is even more helpful.
BTW, thanks for all the diagrams and discussion on this. I'm watching this mod with interest.
bordner42
Brendan
F-150 Lightning Pro
Thanks for reading up more on this relay/fuse block. I haven't been able to install it yet, just had to take my truck in to have a powertrain fault fixed again. If I'm reading into the reviews correctly, they're saying that the switches are activated by the 12V accessory right? But yes, I planned on only wiring the ground from the switches into the overhead console ground wire.
watts/up
23 Pro SR
Sorry to hear about your truck. Hopefully they get it back to you in short order.
Wiring wise, that's how I would do it too: ground and illumination from the overhead harness and then run wires from the six accessory pins to the relay, connecting them to their respective - relay terminals. I guess we wouldn't need the ACC connection in this scenario since switching is coming from the upfitter switches. The power for pins 1 and 9 in C9120 would be run from wherever is easiest or makes the most sense and we have the option to wire some or all of the switches to be always on if needed. I just got a good deal on an overhead console from a Super Duty so I'm thinking of taking this on but I've got some other projects to wrap up first. Again, appreciate your work to figure all this out.
Mcfly
Billy
Tacoma trd off road
Realtor
I just wanted to update that tapping into the violet/gray(illumination) and yellow/black(ground) wires from the over head console harness is correct. This provides the ground and illumination for the upfitter switch panel. They wire to slots 11(illumination) and slot 6(ground) on the upfitter switch harness. Pics below. I havent wired up the rest, will tackel this and update. I'm going to attempt to wire up to an F250 relay panel in the frunk.
Ford F-150 Lightning BCM Pinout Diagram Needed IMG_20250306_123830822
Ford F-150 Lightning BCM Pinout Diagram Needed IMG_20250306_081238957_HDR
Ford F-150 Lightning BCM Pinout Diagram Needed IMG_20250306_081251029_HDR
