Pedaldude
The inefficiency of internal combustion engines and their associated drivelines are so huge, that aerodynamic drag and towing don't impact their range as much as they do in a battery electric vehicle.I do wonder if they have the range extender or something up their sleeve for 2022 or 2023 since most people who know about EVs know the marketing material showing an airstream is at best grossly exaggerated. What would compel the Ford marketing team to show off images of this thing towing? Why then be guarded about the towing range when interviewed by media? Was it just to increase adoption by normal truck users? But then wouldn't there be backlash when they find out it's physically impossible for a current generation battery to do this for longer trips? It seems like they're setting it up for future negative press by pushing the towing as a feature.
The whole thing is very strange, I am very confused.
The only reason why batteries can provide the range that they do, is because of this greater efficiency from the electric drivetrain.
Better aerodynamics also helps in EVs but the Lightning is going to be the worst of all the battery electric vehicles in both drag coefficient and frontal area until the Hummer comes out. I do notice that the Lightning is equipped with aero wheels which should help around 1-2%, which means anyone swapping out their wheels/tires with anything other than land speed record full moon hubcaps and skinnier low rolling resistance tires is in for a surprise!
Despite battery technology always improving, it will probably never reach the energy densities of gasoline and diesel fuel. However, because of the better driveline efficiency, we are already seeing electric sedans that match the range of their fossil fuel powered counterparts.
The main and inherent deficiencies of all battery technologies in comparison with fossil fuel energy is the simple fact that the battery already contains all the energy needed for powering the electric motor. Where in the case of fossil fuel, it's the potential energy being stored in both the fuel you carry in the gas tank and the air that's freely available in the atmosphere. This means roughly, that when you have a 22 gallon tank of gas, you need 2,000 pounds of air to create the energy from the 132 pounds of gas stored in the tank.*
None of the atmospheric air needs to be stored in your gas engine truck and the fuel tank gets lighter as fuel is burned, in the Lightning and every other battery electric vehicle, the battery will weigh the same empty as it does full and that's why it's not as simple as just adding bigger batteries.
To show how far battery technology has come though, there's already battery powered light planes and sail planes that face an even bigger handicap than motor vehicles when it comes to the burdens faced by batteries. In the case of light planes, there's enough endurance to provide basic flight instruction for taking off and landing. For sailplanes, it can be enough for them to take off on their own without a tow plane and then they can fold up the propeller and glide for hours using thermals the same way vultures do. Commercial air transport will be a different story, since big airplanes are basically flying fuel tanks with some room for passengers or cargo. With the 747 and A380 starting to be retired from airlines, it's only a matter of time before air travel starts shrinking in one way or another.
Back to the topic of Ford, they've already filed patents for an in bed range extender and while a kludge, it's better than nothing:
https://fordauthority.com/2020/10/ford-files-patent-for-electric-f-150-range-extending-generator/
A more elegant solution would be a plug in hybrid that takes advantage of the strengths of EV powertrains and dispenses with some of the the worst parts of internal combustion engine powertrains, like the transmission and bevel drive going into the differential housing, which sap a lot of energy from the engine. (Which is notably why Detroit muscle cars had such inflated horsepower figures in the 60's, it was because they were publishing the figures at the flywheel and not the tires.) Honda's new Accord hybrid does this and the experience is seamless, without the transmission a lot of energy loss is eliminated and with electric motors helping acceleration, which they're excellent at, the ICE power unit can use the gasoline in the tank when it's at speed. Something the size of a motorcycle engine could power the F150 Lightning at highway speeds and barely impact any of its other strengths while providing extended range. The only problem is that it wouldn't be a fully electric vehicle anymore but a hybrid powertrain and those are less in vogue now, having been around for decades and becoming so common that one can see them every day without thinking about it. Battery electric vehicles are still novel enough that you notice.
Ford, along with other Detroit manufacturers are so used to obfuscation of their towing numbers that they likely had little hesitation when showing an image of Lightning towing a double axle airstream. They know showing trucks towing shit, splashing through mud and dudes using miter saws on tailgates is going to sell trucks. So whatever justification the executives and marketing department gave themselves, it's now up to engineering and production to make it possible.
*a huge amount of this energy is wasted as heat, through both the radiator and exhaust. Despite this, there's still so much energy left over that even the most inefficient vehicles can travel long distances on fossil fuels.
