Without seeing the door jamb stickers I cannot say for sure. It certainly will have a higher Rear Axle Weight Rating, which could allow it to have a higher GVWR, and thus a higher payload, and a higher tongue weight capacity, but it also will weigh more than the 8.8" standard axle, so it's a game of addition and subtraction, and I wouldn't want to speculate how that comes out.@Roger350 - Does the heavier duty axle increase the payload / GVWR?
Great Catch. This isn't mentioned anywhere, maybe when the brochure comes out...I don't think it was, the first I saw of it was on the production updates, where it listed the Max Tow axles on constraint as a 3/4 Float Axle. A little internet research shows it is a 9.75" ring gear with a different pumpkin shape that is easy to distinguish from the standard axle. Apparently a 3/4 Float setup moves the load path for the truck weight to the outer axle housing, leaving the axle shaft to only be loaded by the engine torque applied to it, and the side load applied when going around corners. I had never heard of this intermediate setup, and didn't find very good cutaway pics of the actual bearing/hub carrier. The standard axle is a semi-float, which requires the axle shaft to carry all the load from the vehicle weight, the side load from turning, and the engine torque applied to it. In an HD full floating axle, like in an F-250, the axle shaft only carries the applied engine torque and none of the weight or side loads.
Tim, I retracted much of this information the other night, as the more research I did, the less I believed my original source. My retraction is on page 1 of the thread.Great Catch. This isn't mentioned anywhere, maybe when the brochure comes out...
10-4. We can hope. I am amazed at the contradictory/lackluster sources of information between the build and price, spec sheets, order guide, and pricing guide. I just know that this wouldn't fly in my job in IT Infrastructure. Specs and interoperability makes it easy to procure, which is perhaps why this is so frustrating for me. I'm trying to make the third largest purchase of my life, and I can't even get solid information on what I have already ordered. If the order bank hadn't been open since July, I would be a little less hard on them.Tim, I retracted much of this information the other night, as the more research I did, the less I believed my original source. My retraction is on page 1 of the thread.
I think the 9.75" Max Tow axle is just a normal semi-floating design, and not some cross between semi-floating and full-floating called a 3/4 floater. I'm not even sure I believe a 3/4 floater is even a real thing, but even if it is, I no longer believe the 9.75" axle is anything more than a regular semi-floater.
Yes, so the rest of the gap is the rims and upgraded brake/bumper. Seems like a lot!The weight of fuel in the tank is already included in the payload calculations.
130 lb difference across wheels, brakes and a bumper reinforcement (probably most of it) seems fair or even low to me.Yes, so the rest of the gap is the rims and upgraded brake/bumper. Seems like a lot!
The 36 gallon tank alone is 88 pound option. Heavier wheels, heavier axle, bigger brakes, beefier hitch makes up the diff pretty easy.Yes, so the rest of the gap is the rims and upgraded brake/bumper. Seems like a lot!
good info, thanks! Glad to know there is an engineer or 2 around hereI don't think it was, the first I saw of it was on the production updates, where it listed the Max Tow axles on constraint as a 3/4 Float Axle. A little internet research shows it is a 9.75" ring gear with a different pumpkin shape that is easy to distinguish from the standard axle. Apparently a 3/4 Float setup moves the load path for the truck weight to the outer axle housing, leaving the axle shaft to only be loaded by the engine torque applied to it, and the side load applied when going around corners. I had never heard of this intermediate setup, and didn't find very good cutaway pics of the actual bearing/hub carrier. The standard axle is a semi-float, which requires the axle shaft to carry all the load from the vehicle weight, the side load from turning, and the engine torque applied to it. In an HD full floating axle, like in an F-250, the axle shaft only carries the applied engine torque and none of the weight or side loads.
