EdwinT
I’m confused by this lol* ordered coolant, yellow antifreeze. Seems like I will need it.
UserName | Location | Build Week | Blend Date | In Production Date | Built | Shipped | Estimated Arrival Date | Arrival Date | Trim | Battery |
Wesley | FL | 11/14/2022 | 11/17/2022 | 11/16/2022 | 12/15/2022 | 1/6/2023 | 1/4/2023 | Lariat | ER | |
balucipher | FL | 11/14/2022 | 11/17/2022 | 11/17/2022 | 12/9/2022 | 12/31/2022 | Lariat | ER | ||
Yabra2 | WA | 11/14/2022 | 11/18/2022 | 11/18/2022 | 12/9/2022 | 12/16/2022 | 1/7/2022 | Lariat | ER | |
tlin | KS | 11/14/2022 | 11/19/2022 | 11/20/2022 | 12/15/2022 | Lariat | ER | |||
Yanni Cake | GA | 11/14/2022 | 11/20/2022 | 11/20/2022 | 12/9/2022 | 12/27/2022 | Lariat | ER |
New ETA 1/22-1/285 left.
UserName Location Build Week Blend Date In Production Date Built Shipped Estimated Arrival Date Arrival Date Trim Battery Wesley FL 11/14/2022 11/17/2022 11/16/2022 12/15/2022 1/6/2023 1/4/2023 Lariat ER balucipher FL 11/14/2022 11/17/2022 11/17/2022 12/9/2022 12/31/2022 Lariat ER Yabra2 WA 11/14/2022 11/18/2022 11/18/2022 12/9/2022 12/16/2022 1/7/2022 Lariat ER tlin KS 11/14/2022 11/19/2022 11/20/2022 12/15/2022 Lariat ER Yanni Cake GA 11/14/2022 11/20/2022 11/20/2022 12/9/2022 12/27/2022 Lariat ER
I have a 1000 miles on my xlt SR and just checked it for the first time while removing the front beeper. The fluid was still right in the middle, no loss at all.Well, it's not a joke, if you look in your front trunk there is a reservoir for coolant. Keeps the battery and electric motor cooled. Heat is the enemy of batteries. Don't neglect that.
I get that but I thought the coolants had a very infrequent change cycle? And nothing should be consuming them right?Well, it's not a joke, if you look in your front trunk there is a reservoir for coolant. Keeps the battery and electric motor cooled. Heat is the enemy of batteries. Don't neglect that.
Coolant should very infrequently need to be checked and topped off. Similar to coolant in an ICE vehicle... It's really only a problem if there's a leak. Another forum member started a thread about this and that he's noticing low coolant level, which probably means he has a leak somewhere. I think it's made a few members here paranoid. Yes, sure, check the levels and all that, but unless you're pushing the vehicle extra hard in both driving and charging or you have a leak, that coolant shouldn't need a top off more than every 10~15K miles or more.I get that but I thought the coolants had a very infrequent change cycle? And nothing should be consuming them right?
New ETA 1/28 to 2/3. Still not in shipped status yet5 left.
I am not planning to keep it in the truck, but I guess I have a OCD personality so whenever I buy something I try to get the most common "spare parts" stocked in case I need it. I dont expect to loose any, hopefully, but if I do and have a trip planned it will be in the garage with the spare parts for my house.I get that but I thought the coolants had a very infrequent change cycle? And nothing should be consuming them right?
Are you going to drive around with it just incase ?
Shipped on 1/7/23. Estimated delivery is still 1/21-1/28.5 left.
Truck arrivedDid u contact Ford customer service about status? They could tell u the last rail check point and rail car number..
Last time I contacted them they mentioned my truck now is eta 1/20 at dealer
Yes got the email from Ford to complete the purchase and dealer contacted me.. hopefully it will happen before the end of week! Looking forwardTruck arrived
Try unplugging the 12v for ~10minutes (probably less)... I had trouble activating and tried all available resets and reinstalls in both truck and on the phone. After plugging back in the 12v battery and waiting for it to cold boot up was able to activate the truck with the Ford Pass app without any issue. BTW: Just pull the frunk closed by hand after restoring the 12v.same issue as many others with modem and activation which customer service said they have a fix ETA early Feb.
Today it worked .. probably got the modem update via WiFi.. so am able to activate it now but my bluecruise map still out of date.. Will wait for more updates I guess.Try unplugging the 12v for ~10minutes (probably less)... I had trouble activating and tried all available resets and reinstalls in both truck and on the phone. After plugging back in the 12v battery and waiting for it to cold boot up was able to activate the truck with the Ford Pass app without any issue. BTW: Just pull the frunk closed by hand after restoring the 12v.![]()
