100% but only at 90% charged
Quarter2heavy
Jason
Connecticut
Truck is set to charge to 90%, recently I have been seeing the app state 100% charged, and when I first enter the truck the dash shows it at 100% as well, but as soon as I start the truck its at 90%, like it should. No I haven't used the charge to a 100% options either, this is the 3rd day in a row of this. I did notice that the range according to the app is about the same between 100% and 90%. I typically get around 285 range for 90%, but even at 100% the range is still around 285. Details of charge state target of 100% while the settings show 90% target
Some have reported instant incremental jumps in state of charge being diagnosed as a bad cell in the HVB. Do you have a scanner to check for DTCs?
If the app differs from the vehicle, log in via a website browser and see what it says. 9/10 times it is the app lagging.
But he stated that it showed 100% in the truck, immediately dropping to 90 after starting.
trev5150
Banned
Banned
Banned
Trev
Pilot of pilotless things
This week I had yet another update stating that they improved range estimation, and overnight my truck charged to 100%. The next night it was normal. Check it again after another charge and see if it’s repeatable.
ivan256
Massachusetts
2022 Lightning Lariat ER
If it's the same update I've got, it didn't actually say it improved range estimation. It said it changed range estimation to show what's possible if you drive efficiently. To me that means if you choose to drive inefficiently it will show a less-accurate estimate of your range.
(I chose to disable updates rather than install it, so I can't say for sure what it actually does - only what the note said.)
trev5150
Banned
Banned
Banned
Trev
Ok I didn’t quote the update text word for word, but that’s the one.
Quarter2heavy
Jason
Connecticut
Update, I opened the door a couple days ago only for the screen to say 0%, closed the door did it again a few mins later, and it showed 100. App showed 100%. Started the truck and it was at 95% but dropped to 90 by the time I rolled 45'.
Yesterday, after reviewing other posts, I change my charge schedule from charge when plugged in and went back to preferred times. So far everything is back to normal
Thinking there is a software confusion when using the FCSP.
