Heds43
Hendrick
F150 and F250
Instrumentalist
Nice thread
Heds43
Hendrick
F150 and F250
Instrumentalist
i would like a defender
Shawnson
Edmonton
Lightning Lartiat ER, Model 3 LR, Crosstrekā€¦ hehe
Developer
Here is a quote from an article that itself is quoting a Michelin official:
ā€œTorque to me: EV tires wear down faster
Electric vehicles also exert more torque, or rotational force, than equivalent gas-powered cars.
This happens for two reasons: The highly efficient electric drivetrains deliver sports-car-like acceleration, even in a boxy little compact. That means EVs put more pressure on tires than vehicles that accelerate more slowly.
EVs also exert torque in reverse through regenerative braking. This is the feature that takes energy from a car slowing down and converts it into a little extra charge for the battery.
Any type of braking applies torque on the tires, Shepherd said. But EVs do this more often, and they skip the coasting period between acceleration and braking, jumping straight from propulsion to regenerative braking.
ā€œThat additional braking does contribute to the faster wear of the tires,ā€ Shepherd said.
This leaves an EV driver with two options: mentally prepare to replace EV tires more frequently, or invest in tires with greater ā€œwearā€ or longevity.ā€
seems like an argument in logic vs practice to me. If you regen slowly (smoothly) then it shouldnā€™t be different than braking smoothly at the same rate. If youā€™re one of those EV drivers making your passengers want to puke because you fully jump off the accelerator, then I doubt youā€™re also smooth at braking with friction brakesā€¦. I fully get the logic, but I donā€™t see it being meaningful in practice.
Tom Jensen
Arlington, Virginia
F-150 Lightning 2023
Attorney
Why would regenerative braking wear the tires any more noticeably than just having gobs of torque available. Who brakes lighter than regen?
I think we are all about to witness and experience a big evolution in tires. The demands of EVs are one thing. But the new science (and litigation) linking tire chemicals to mass die-offs of coho salmon in Puget Sound is likely more consequential in terms of local environmental impacts. If current tire chemistry is a nearly guaranteed death sentence for salmon, it probably isnā€™t good for other living things in all sorts of places far from salmon streams outside Tacoma. Iā€™ll wager that 5 years from now we will be dealing with a very different ā€” and better ā€” product.
N87
Leo
communic2
23 FL
...I went with the Cooper Discover Road and Trial AT. Nice tire, looks great on the truck, minimal road noise BUT major loss in efficiency. Plus add the cold weather now and uuugh!...
What's the mi/kwh you're getting with with the Coopers and cold weather? Road and Trail AT are one the choices I consider as my next set.
jlferg0509
Jeff
Dayton
2015 Chevrolet Malibu; 2023 Ford F-150 Lightning
I'm actually on the first road trip (235 miles) since getting them. Temperature during the drive was approximately 45 degrees, I averaged 70 mph, not a whole lot of wind, and got 1.7 - 1.8 mi/kwh.
I started the trip fully charged the GOM, showed 320 miles of range @ 100 %. When I arrived, I was down to 9% and 20 miles of range remaining. I stopped and charged at a Tesla supercharger to about 75%, expecting temps to dip below 20 degrees later today.
scruvs
All things being equal, Iā€™d guess Iā€™ll get closer to 50-60k out of these. I had Primacyā€™s on my ā€˜18 F-150 and looked the same at 38k miles as the one I just replaced with 33k. The Primacyā€™s are quiet when new but donā€™t last long (400+_ tread wear) , arenā€™t great in snow, and cup on the edges. Plus, theyā€™re almost the same price as Defenders.
Iā€™ve decided that Iā€™m going to also replace my Primacy XCā€™s with Defender LTX M/S2. Iā€™m right in the same wheelhouse with having to replace the Primacyā€™s at 32k-33k. Iā€™d be very happy with 50-60k if that turns out to be the case.
Ford noted uneven wear on my Primacyā€™s and recommended an alignment. Iā€™m hesitant though because the truck ā€œfeelsā€ fine. Iā€™ll have to think about the alignment a little more.
roddiaz1
Rod
Pittsburgh
If you don't mind me asking, what kind of ware do you have? Is it mostly on the outer edge/shoulder of the front tires?
Thanks in advance.
