320 mile range displayed? (2024 extended range) SOLVED! thanks all.
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
Hi, I bought one of these 2024 lightnings last month and the advertised range on the factory sticker is 320 miles. I understand that I may or may not obtain this range based on blah blah blah. HOWEVER, shouldn't my display state that when I charge to 100% that 320 miles is anticipated? Mine is not showing that. I shows only 273. WTF? Any ideas?
The truck knows what the ambient temperature is. The truck also studies your driving habits. Then it makes calculations based on numerous algorithms.
Al_V
Allen
Canton, Ohio
Interesting that Version 4.x.x is still available.
The iPhone XR is compatible with iOS 12 and all subsequent iOS updates, including iOS 18.3 (current). The iPhone XR came with iOS 12 pre-installed.
iPhones can get their operating systems updated for many years until Apple decides the hardware won't efficiently support it.
The iPhone XR can be updated to the latest iOS and run the latest Fordpass.
I have mild winter temps as well, so I find that my driving efficiency has the most impact on my predicted range. My commute is primarily city so I have a high range prediction most of the time. However, when I return from a road trip, I always see a big reduction in my prediction. It doesn't mean I have less range, I know my commute efficiency and I just drive it accordingly. The truck eventually figures it out and I see the predicted range start climbing after a couple weeks.
22legit2quit
2024 Ford Lightning Flash ER
Mine will do it occasionally. I’ll take a picture next time it does if I remember. A lot of the folks on here are right. It is something that they changed for the epa.
There is also nominal and actual values for things that will change, 320 is a pipe dream (currently) unless you are doing 50 or less, no fun, no heat, etc.
Lastly, the furthest I have ever been comfortable going on a charge was 250 miles. That was one of the times it said 320, when I arrived it had 15 miles (what it said), which is probably fairly accurate. This was all highway driving in 80ish weather.
NYCLABORER79
Sal
NYC
2024 FORD F150 LIGHTNING FLASH ER
You need to reset your EV driving history
