400w 120v Bed Outlet doesn't power much
CBGray
Chad
Washington
'21 Lariat 2.7L EB Screw 4x4 501A
Software
How many Watts would an air mattress pump pull?
Saw a review on Amazon where this Coleman one drew 230W. Model: 2000021141. Someone else there had the same question, and an owner of the pump said that's what was written on it.
kdkool
Atlanta, GA
2023 XLT Lightning / 2023 6.7L Lariat F-350
I have the 400W inverter in my 2015. It's a modified sine wave inverter that doesn't operate anything with an AC motor well if at all. It'll power a laptop and my milwaukee chargers fine though. Key has to be on, and engine running. If auto-stop start is enabled, my socket shuts off when the engine shuts off at a red light.
Buschlatte
Downriver MI
F-150
Oddly enough I have only used that plug to power a baby bottle warmer and it worked just fine. Bottle warmer said 500w, didnt think it would run.
Asphaltman
Salt Lake City
2021 F150 (produced 2/11) 2018 F-150 1997 F-250HD
Entrepreneur
Anyone know the amps of the 400 w plug?
Merccat
Ryan
2021 Space White Lariat SCAB 5.0 4x2
Around 3-4 but I would only count on 3.
I opted for the 2kw pro power (5.0) for a little more capability if needed.
Asphaltman
Salt Lake City
Entrepreneur
Thanks for the info. Honestly, the pro power was one option I didn’t get, and now wished I had of.
Jaylars
Jay
Idaho
2008 5.4 XLT SCREW and 2021 5.0 XLT SCREW
Military
Something like this would make sense while traveling/camping long distance.
Fridge
Vulnox
Bob
Livonia, MI
2021 F-150 Lariat 502A, 3.5L PowerBoost
Keep in mind when looking at what to run on the outlets that most motors have a surge draw and the outlet won't work. Someone mentioned an air pump for a mattress at 230 watts, while not guaranteed, I would not be surprised if that didn't work on the 400W outlet. Surge draw can be 2-3x running draw, so 460+ watts at start, and the outlet would trip.
Maybe not, some camping stuff tries to design their motors to start "softer" knowing that capacity is often limited, but the cheaper stuff is likely just lowest bidder sourced motors and they could have crazy draw at startup.
sglide05
Todd
Vancouver, Washington
2021 XLT
Since it's supplying 400w and it says it's 110v, it's a simple math problem of 400/110, should be right around 3.6A.
You're right. I was doing the math wrong. I agree around 3.6 amps.
Longhorngary
Austin, Texas
2017 Ford F150 302A soon to be 2021 F150 KR PB
My truck is an XLT 302A, it does not have Pro Power buttons anywhere, so I assume it does not have Pro Power. The window sticker shows it has "Onboard 400w Outlet" and the it has an outlet in the bed with 400w, 120v with the light always on. This outlet really doesn't run much expect phones, and small stuff. It would not run a blow dryer or vacuum. Am I doing something wrong or is this just a standard plug like on the inside and worthless for actual power tools? Just trying to get to know the trucks capabilities.
You can plug in a phone charge or a radio. Not much more powerful. One of the reasons I opted for the powerboost.
Jaylars
Jay
Idaho
Military
Rv frig will run off propane when traveling, uses very little gas, a 20 pound tank lasts us a few years, don't need a generator for that.
You installed an RV fridge in your bed? I thought there were DOT laws about hauling operational propane in an open bed.
Sounds interesting though, send pics, would like to see that set up.
Lpetters84
Landon
Kentucky
2021 F-150 Platinum FX4 5.0
Anyone swapped out the 400w converter with a slightly bigger one? I’m wondering if this is possible?
