Rocky Wabbit
- First Name
- Rocky
- Mar 3, 2021
- California
- 2 F150's
- Occupation
- retired
Well; if you want to experience a lying P.O.C of Junk, just buy it ! Or just experience an awesome adventure ! The truth about 7200 watts of power capability take some ability of power !
The Champion Power Equipment 100248 7200-Watt Portable Generator is designed with your safety and convenience in mind. A cost-effective solution that delivers power and peace of mind, this generator will provide all the backup power you need for power outages and emergencies. For projects, the 439cc Champion single-cylinder OHV engine has what it takes to handle multiple power tools at the same time so you can get the job done.
Championās Volt Guardā¢ built-in surge protector prevents overloads and keeps your equipment safe from spikes in voltage and the voltmeter allows you to easily monitor power output anytime.
The convenient electric start includes a battery, plus Cold Start Technology ensures a quick start in cold weather.
At 9000 starting watts and 7200 running watts, this unit can handle it all in an outage ā lights, refrigerator, modem/router, security system, window AC, furnace blower, TV, computer, phone charger and more.
Plenty of outlets are available, including 120/240V 30A (L14-30R) and 120V 30A (L5-30R) locking outlets and four 120V 20A household outlets (5-20R).
Fill up the 6.1-gallon tank of gasoline, run at 50% and enjoy up to 8 hours of power. From 23 feet, the noise level is 74 dBA, a bit louder than a vacuum cleaner.
Designed for safety with convenient push-to-reset circuit breakers and a low oil shut-off sensor, this unit has a 1.2-quart oil capacity (recommended 10W-30) and comes with an oil funnel for easy changes.
Mobility is never an issue with this rugged generator. The foldaway U-shaped handle and never-flat tires in the included wheel kit make it a cinch to move your power where you need it.
This generator is EPA certified. Buy with confidence - our reliable support and network of service centers will back your purchase up with a 3-year limited warranty and FREE lifetime technical support.
