Add on trailer brake controller - possible for Lightning?
FoxRidgeFarm
Gordy
Ford F150 Lightning Pro
Farmer
Hi
I bought on 11/30 -12/1/24 a 2024 SR Pro with no max trailer tow package or trailer technology package.
The sales man sold me a spray in bed liner and a trailer brake. This Wednesday I brought it in for the bed liner and the trailer brake. The bed liner was done yesterday.
After 3 hours of working on the Trailer Brake Wednesday and a few more hours working on it today and frying a tail light control module (which they have to order and replace), today the Service Manager called me saying they couldn't do it.
I received some information from EV Mariner as to which dealer in Maine got his brake going. I offered the information to the Service Manager whom said he didn't care.
My son who runs the maintenance department for a contracting firm, works with another dealer for their commerical trucks says don't let Ford off the hook.
I have on the farm here semi tractors and other heavy vehicles.
It does not make any sense for afford to put a Class IV hitch (10,000# capable) and an anti-sway on a F150 lightning capable of towing 5,500#, but limited to 3,500# without installing a trailer brake, which is not possible.
I am openly for advice here.
The trailer brake and bedliner was wrapped into the financing.
Thanks looking for an idea here.
The farmer
mxracer
2024 F-150 Lightning Flash
I installed my trailer brake controller in my 24 flash just today.
Ford part number is RL3Z-19H332-AA
(Part number for 23 and earlier is RL3Z-19H332-AB)
It took all of 10 minutes to install and another 5 minutes with forscan to update the IPC.
I bought it on "the bay" from FairwayFordParts, if you search that part number on "the bay" it will be the first result.
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Flash
This is wrong for the 24 lightning correct for 24 ice trucks
Jesse-Infotainment
Jesse
Dallas
22-24 Lighting uses ML3Z19H332AB
mxracer
It works, installed, programed, hooked to my tilt trailer and have gain and brakes with controller in dash and no faults?
Maybe they both work?
Jesse-Infotainment
Jesse
Dallas
no its wrong
it runs entirely different firmware
Jesse-Infotainment
Jesse
Dallas
What's the consequences of having it in my truck?
I dont know. I have to be careful of what information is distributed. I dont want someone to buy a wrong part and not know.
I know 100% the TRM part number for the 22-25 Lightning.
I do not know the consequences of the wrong one. MAy be none.. but not knowing I would not want someone to find out the hard way.
SO I have to make sure when a post is made with incorrect info that i correct it.
FOrd ships them with a specific one. I have a 24 Flash also and installed the TRM and dug into it all.
So you may not experience any issue but ford didnt ship it with that one for a reason. The 24 F150 runs Super Duty firmware. It runs a new EPROM as well .
21st Century Truck
Martin
Yeah, I can't imagine the tow package not including a brake controller, but if for some odd reason it doesn't, I've been using the Curt Echo bluetooth brake controller with my BMW X3 for almost a year and I'm pretty happy with it. The device almost looks like a small scope you stick between the 7-pin connecter and the trailer. The companion app is pretty rough around the edges but it works well enough and I didn't have to mount anything inside the car. On top of that, it's really easy to swap between tow vehicles.
+1 on all points.
Jesse-Infotainment
Jesse
Dallas
Ford F-150 Lightning Add on trailer brake controller - possible for Lightning? 1735044660047-i2
From Fords page about the 2024 Trailer Brake module
mxracer
This is honestly one of the biggest points of confusion for me and one reason why I ordered the wrong thing. All of them for the F150 say that including ML3Z19H332AB.
Appreciate your info/help. I'll scrounge up a ML3Z19H332AB module and get it in the truck.
Jesse-Infotainment
Jesse
Dallas
Since you already have the pincher you only need the module not the whole kit
ML3Z19H332J
That is the module part number.
mxracer
Thanks for your help @Jesse-Infotainment , I was able to work with the dealer I bought the original kit from and exchange it for the correct one you mentioned above.
Note that the "consequences" were that sometimes on start up I'd get a TRM fault message with the incorrect module.
Jesse-Infotainment
Jesse
Dallas
Ok. Glad you were able to get it swapped out.
