Adding brake lights
Azgunguy
Michael
Northern Arizona
2023 Lightning Pro and 2012 Expedition Fleet
Adding emergency lights to my truck, and typically on other builds when I’d integrate them into brake lights, I’d just splice into the tail light wiring. Is that feasible on these trucks? It’s along the lines of adding a light bar under the tail gate.
beefcake
Diamond Sponsor
Beefcake
Cincinnati, OH
22 f150
Owner Beefcake Racing
havent tried that... we have had luck with the rough country light controller.
Ecstatic
Bret
Spokane
‘03 Highlander, ‘83 Landcruiser, ‘22 Lightning Pro
Temporarily retired
Did you have any luck figuring this out? I also have a Pro. I believe it has a plug in the wiring under the bed near the spare tire, which is what the trims with the tailgate light bar plug into. I’m wondering if it’s possible to plug an aftermarket light bar into that. I’m making a camper and looking into wiring in a third brake light.
Azgunguy
Azgunguy
Michael
Northern Arizona
I didn’t go through with anything. But I did discover splicing into a tail light wire works.
Delmar
2024 Ford Lightning Flash
Compliance Enforcement Agent
Did you remove a tail light and just splice into the wiring?
If so, do you remember what the color of the wiring set up was?
I am going to add a red running light across the tail gate since, my flash didnt have one.
Plus, I need to splice into the front turn signal wiring too but, can't find any diagrams or color chart for the wiring.
broncoaz
Cape Cod, MA
Delmar
astrand1
Alex
Studio truck driver
Ok, I see. I've read that tying into the trailer harness will trick the truck into towing mode and turn off rear sensors and cameras and range estimates.
More than likely it will.
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 37 years. Worked on everything from Lawn mowers to Boeing 747's.
I did this for brighter reverse lighting. Used the trailer plug in, didn't want to cut into wiring. 1st couple of times the truck did want to know which trailer I was towing. But after a few times of canceling the tow alert. Seems to have learned that there isn't one. Still every once in a while it will give the alert. But this works fine. Actually don't care for the looks. But it works.
broncoaz
Cape Cod, MA
I wired my lights into the 7 pin harness adapter as planned. Everything works fine and I haven’t had any tow alerts since the install last Friday. The lights are the Diode Dynamics SSC1. I made some brackets out of stainless steel.
Ford F-150 Lightning Adding brake lights IMG_0403
Ford F-150 Lightning Adding brake lights IMG_0404
Ford F-150 Lightning Adding brake lights IMG_0408
Ford F-150 Lightning Adding brake lights IMG_0407
