Aftermarket OEM Tow Mirror Not Telescoping
Cody
Cody
Alaska
F150
Flight Instructor
I bought aftermarket OEM tow mirrors from ford, part number ending in DA. I have all the other bells and whistles working (aside from marking lights and power telescoping). I’ve read forscan is the answer for the marking lights, but haven’t been able to find anything about the telescoping mirrors. New switch is mounted and plugged in but nothing moves when I press it. Anyone else upgrade to the DA mirrors and resolve this issue?
SC_Sparky
Doug
23 Platinum Black
Hello, did you ever figure this out?
Note this is a post from early 2022 before there were Lightnings. Back then our forum was combined with them. Cody has not been on here since April 2022. He drove an ICE F-150.
Ford F-150 Lightning Aftermarket OEM Tow Mirror Not Telescoping 1725401477898-q
If you are having the issue you might want to try the ICE forum. They have at least ten times the folks trying to do aftermarket installs. While there could be someone on here, it is more likely the ICE folks have done it. Good luck.
