Back Charging my Lightning using pro-power ports
whatsagrid
Jupiter Florida
2022 F150 Lightning Pro
Part of me still wondered if this is a joke/troll.
Once again, no there is no means by which you can hotwire a few solar panels directly into the battery. That is not how anything works. The fact that you use double male extension death cords to backfeed your hose with a generator is very telling. My recommendation is stop trying to kill yourself and other with ridiculous electrical hacks.
Every Great Leap Forward looked like a ridiculous hack to a majority of the people. Ridicule is always a good sign that real progress is being made.
Thread title fixed.
I've mulled over, and calculated to infinity, the idea of trying to be 'off-grid' with EV charging... but, I've come to the same end-conclusion each time:
it's too costly. Solar is expensive. Electricians ain't cheap. A battery bank ain't either.
it's too much work. Solar panels and equipment installations aren't 'easy'.
it's unreliable. The sun is not consistent.
it's too much room on the roof or in the yard. Shade doesn't help, either.
it's too much additional equipment. DC Solar output can't go directly to an EV.
it's too much future maintenance.
it's too much headache.
it just doesn't make 'practical' sense.
now, if you don't have ANY options for grid power, then, well, that's a different story - but I'll bet that those in that situation probably aren't going to be EV owners, either.
Solar power is not a good Compatible power option for the very HIGH amperage and LONG TERM CONSISTENT output that EV's require.
Runaway Tractor
Yes
So your attitude is just keep asking the same question with slightly different words until someone tells you what you want to hear. The problem is what you want to hear is not possible. That is not the fault of people telling you no. That is the fault of you wanting to do something that isn't possible.
mq019
2023 F150 Lightning Lariat ER
I’m ok with charging while the truck is in park for now. The regen braking charges the truck while moving so it’s not a physics law that makes it impossible. Also the new Ram EV Truck has an onboard generator that charges the truck while moving.
If we ignore the limits of solar for now and focus on what I want, which is a secondary charging port on the truck then it is feasible to consider putting a generator in the bed of the truck and using it as a range extender. I could burn biodiesel and stop at restaurants to get their used cooking oil maybe more effectively than installing solar panels for the next decade until the solar tech catches up. I could pull a wood burning steam engine if I wanted to drive to Alaska. Last I looked there is plenty of wood there.
Every EV is a serial hybrid. The only difference between them is whether power is onboard or offboard. In the case of a Tesla the power is generated from the grid. In the new Ram EV truck the power is generated onboard. There is going to be a revolution in alternative power sources from mini nuclear to campsite steam engines etc and I want to modify my truck to get ahead of the curve.
I dont know that anyone has said that its impossible to do. BUT - lots of things are possible that just dont make sense and arent going to happen, for whatever reason.
For example - Its not physically impossible for you to build a rocket in your backyard to send a satellite to orbit, but realistically, it isnt going to happen for an entire myriad of reasons.
You can continue to imply or even state flat out that we're all too simple minded, and not visionary enough to see the possibilities, and it might make you feel better but it doesn't change the reality.
A current model Ford Lightning will NEVER charge while it drives. Not because physics make it impossible, but because it was literally designed and engineered to not do that. It would require making changes to the HW and SW to not just make it do something it wasn't designed to do, but to do something that it was expressly designed not to do. It would be easier, cheaper, and faster to just buy an old truck, pull the entire drivetrain out, and build your own electric truck from scratch - motors, battery, charge controllers, SW, etc.
The cost and level of effort to make a Lightning do this would be so ridiculous that it would make more sense if you want that capability to buy the Ram that you were referring to that is designed from scratch to do what you want, or if you've recently won a $10M+ lottery and don't have anything better to do with the money, you could just design and engineer exactly what you want.
In any case...... Good luck! 🤷‍♂️
