Blind spot system and rear cross detection fault
CallaDrilling
Berlin, NJ
2022 Ford Lightning Lariat
WellDriller
I have the same exact issue.
Taillight cracked, water in the light ruined the sensor and getting continuous notifications on my screen.
vagabond7846
NJ
did you get this resolved or y ou still have issue?
Arctic_czar
Matt
Washington
Ford F150 lightning
I have a similar issue. Had a rock go through the tail light, which promptly filled up with water and now reports the cross traffic and blind spot sensor issue. I replaced the cover for $1400 and tried to transfer the module but I'm still getting the same error. Has anyone had success replacing the module? Are they prone to water damage?
Ford F-150 Lightning Blind spot system and rear cross detection fault 20240102_180627
CallaDrilling
Berlin, NJ
WellDriller
Module has to be programmed. It’s not just plug and play.
Instructor911
Adam
Duncansville PA
2022 Lightning Lariat ER
I have this problem now. I connected a little sailboat trailer with a 4 prong connector and it worked fine towing it 20 miles. As soon as I disconnected the trailer I get both of these errors. I tried disconnecting the 12v battery for 2 hours and still nothing. Any ideas? I searched all around and I can't find anything. I double checked the connector in the bumper and I don't see any damage or problem with it.
