robertantal
Love this! Thanks for sharing your camping adventure with us, Robert!
Would be nice if you could somehow vent thru the rear sliding window for Heat/AC.
Great post. Any complaint about the tent? Anything you particularly like about it (the reasons you picked it over others)?This is a Kodiak Canvas truck tent available for around $500 on most camping sites. There is a full size 6ft and a full size 8ft version and both will fit the Lightning. I opted for the 8ft version and I tucked the extra material behind the cab. It was just personal choice.
This guy used it but want to go back to ground tents (min 11:11):
Yup, power in the back opens up all kinda options. Then again, depending on how often you use that heat/AC unit, cost of that unit could make the case for a few nights in Hilton insteadNo complains so far!
Heating/cooling can be achieved with a portable ac/heat unit since you have 110 available in the bed.
https://a.co/d/3jBcaGh
Some ducts could be connected to the rear seat AC outlets and run trough the rear window and the tent lower window what can be zipped open for a less expensive setup.
Amazon sells the bed mat with memory foam and self inflating for $99.
https://a.co/d/eI1Di4o
I also use the sliding bed cover as a table or seating area. My daughter even comes to sleep on it sometimes since it can be locked at any position.
Your registration is expired.my camper likes it, too... thanks to the ProPower while driving, and my ingenuity of installing a 20amp heavy-duty OUTLET at the rear of the LIGHTNING, to power the Camper while traveling...
wired directly to a 20amp heavy duty ext cord, that simply runs behind the bumper and up into the bed, to plug into an outlet, when towing...
Looks good! Thanks for sharing this with us, Glenn!Here's my Lightning XLT ER.
