Can you actually get the screen's clock to stay in 24-hour mode?
myke
myke
MikeGeiger.ca
'23 XLT ER, '14 FJ Cruiser 6MT
IT/Networking/ISP/OSP Consultant
Are you receiving available updates and allowing them to install?
What is your most recent OTA?
Auto-updates are scheduled, and while I'm in Canada and the SOC display took nearly a year after the Americans got it, there was a flurry of them a few months ago but nothing recently. (Can't actually tell you the latest update right now.)
... either way this isn't a bug that should exist at all. It's not like the GUI software was written from zero for the Lightning...
K6CCC
Glendora, Calif.
2024 Lightning Flash in Antimatter Blue, 2017 Toyota Corolla
Two Way radio systems
I also am seeing the clock revert to 12 hour every time I start it up. Only had it a week and a half.
astrand1
Alex
Studio truck driver
Ok I had this same issue. The brain trust here figured it out. There is a setting in forscan on the APIM I think to default to 24hr. I changed that a few months ago and problem solved.
K6CCC
Glendora, Calif.
Thanks. I have downloaded ForScan and received the recommended OBDII adapter so expect to be playing with that this weekend.
B177y
Bill
Northwest of Northwest WA
www.ptcoffee.com
2024 Lightning Pro ER Max Tow
Coffee Roasting
I saw this mod in the ForScan thread a few weeks ago and asked there if this made the 24-hour clock persistent or if it still randomly switched back to 12-hour. Never received an answer there, so thank you for adding confirmation that this works 👍
Guys, be careful with this. In scanning for the "fix", I found this post which identified
IPC 720-01-02 xx*x-xx--
People interpreted the post incorrectly and started to change their values to 0, C, etc. Some of these are wrong for us. In looking at Lightnings, they all have a "2" here. To keep those same settings and change Global Clock from 12 to 24-hour, you need a "6".
If you previously disabled the Engine On Chime (i.e., you changed the "2" to a "0), then for 24-hour clock you need a "4".
I have updated the FORScan mod post to be more clear.
Disable Door Ajar Chime
12/24-Hour Clock
IPC 720-01-02 xx*x xx--
0 12-hour clock, Chime disabled
2 12-hour clock, Chime enabled (default)
4 24-hour clock, Chime disabled
6 24-hour clock, Chime enabled
