Charge pro station yellow light after only 30 mins of charge
I do not see how software could cause a shutdown. The current limit is set physically on the box. I tried to set it lower and I still had the problem so I set it back to 7 or80 amps and now it seems to work better. At least it does not stay yellow, somehow it goes back to charging. But a night time failure in charging will cause me a lot of grief. If I need the truck the next day it better be charged.
Now that it's working a full rate , don't fool with it, the problem is with the communication of what we want the change to be {lower / higher}, the system is not reliably following our change requests
Rule to live by, set it and forget it, all will be fine. ........ until a rouge OTA screws up our charge scheme.
RichieF556
Richie
2023 Ford Lighting
Acquisition Analyst
I'll try that today, thank you!
99% likely the Fordpass app that controls charge rate is the cause, keep trying to push it to 80 amps. eventually it goes away, if it's not SYNCING UP, you might try a new reset & setup process.
'looks' like changing the charge rate is working so far! Thx!
