Ajzride
Alan
Houston
Eng
I'll see if I can get it installed after I figure out how to get this extremely short power cable ran to the obd port.
I cut it down and solder sealed it back together.
Drayday55
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
Also, Ferrite does Jack on the comma power cable. Installed one on each end and a loop in the middle.
Ferrite installed on every cable in everyway possible way and it still flashes errors for about 5 seconds on startup. So harness modification looks like the only good solution still.
I can also confirm the ferrite choke does nothing.
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I was going to ask if it could be shortened. Wasn't sure what all it's sending through the cables. I'll cut it down once I have time to play with the unit.
UncleTony
Tony
How long do you get errors for? Mine are just long enough to popup the message then they are clear. I'm not sure this bugs me enough to mess with it more than I have.
UncleTony
Tony
Ok, for those that are ordering new kits..
Comma sends you all you need now for the F-150 platform. They now include the long USB C cable with a USB C to USB C connector and the 90 degree standard cable. I taped my connectors with Electrical tape because I was thinking it would end up under the headliner. Now that it is installed, it sits right next to the rearview mirror casing. Leaving the tape as of now because the adapter is silver and it looks better black.
If you want to use Blue Pilot, it seems you will have to use the link @Ajzride posted for staging
installer.comma.ai/bluepilotdev/staging-2.1
otherwise you get stuck on the registration.
Blue pilot is way better than (Base) sunnyride after about a 20 mile comparison on each.
Personally I am going to leave the stock harness on my setup for the time being due to the startup errors being pretty minimal and the fact that I almost always remote start the truck.
1000% times better than blue cruise.
Edit to Add: Ferrites won't do anything to resolve the issue, in my case, I had no errors until I plugged in the USB C and comma unit.
