ZSC100
Zach
Tulsa, OK
Electrical Engineer
That's an awesome radar array, thanks for posting this. Interesting to note the horizontal asymmetry for it being mounted on the drivers side. I would love to talk to the ONE engineer on the planet who created/tested the calibration software service procedure for this. I can imagine it maps items/cars along the road and correlates/calibrates it with the vision system's interpretation of the lane markings. It's very impressive that we've come this far with the hardware technology yet still only have Level2 vehicle autonomy :(.
Azgunguy
Michael
Northern Arizona
2023 Lightning Pro and 2012 Expedition Fleet
Eh. Level 2.5 with a water bottle in the steering wheel 🥲. It’s super interesting looking at it. It just sucks how easy it is for water to get inside of it.
Azgunguy
Michael
Northern Arizona
Another sensor invaded by water. The sensor still works. I get the “sensor blocked” warning after driving for a few minutes. If I pull over stop and start the truck, then engage the ACC it works fine for the rest of the drive. I think it’s still salvageable. I’m going to clean it up with some IPA and then silicone it closed and run some dielectric grease in the connector. For all you current and future users!!! I’d recommend a bit of schmoo in the connector at least
So I was able to fix it. I let it sit out in the sun to dry off. Rinsed it with rubbing alcohol and let it drain out the vent holes where the connection port is. I then ran a bead of silicone around on the top side of this unit (the lid?) and put it back together and let it sit in clamps overnight. It needs to be recalibrated but on a 20mi highway drive to work all is well. I think I got to it soon enough (1 week) so not too much corrosion set in. And maybe not enough water was in there to cause terrible damage.
Fxnitro
Pedro
PA
F-150-Lightning
Yea, that looks correct. Remember polarity on the CAN pins also matters.
My CCM won’t show up even after making the changes to the IPMA to power it… I believe I have a polarity issue, my question is the 4 wires coming from CCM, how should they be inserted into the IPMA, I connected them randomly into the 4 slots available which I numbered on my picture
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT IMG_4929
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT IMG_4933
Ford F-150 Lightning DIY: Installing ACC (Adaptive Cruise Control) and LKA (Lane Keep Alert) to 2022 F-150 Lightning XLT IMG_4939
rio
CT
2016 Chevy Volt, 2023 F150 Lightning Pro
From the way you labeled your IPMA connector pins:
#1 (which is actually IPMA pin 20) goes to CCM pin 3 (CAN+ signal)
#2 (which is actually IPMA pin 19) goes to CCM pin 2 (CAN- signal)
#3 (which is actually IPMA pin 18) goes to CCM pin 1 (sensor power)
#4 (which is actually IPMA pin 9) goes to CCM pin 4 (sensor ground)
OIF_VETERAN04
Joseph
2023 F150 Regular Cab XLT
Hello,
Can this be done if you don't have the 12" digital cluster? I have the 8" cluster.
