Audiowerksnyc
Good evening guys this is my first post on the forum and I just wanted to put some information out there that may be helpful to others with the same issue that I’m having. I’ve had my truck for about a month and I have been having an annoying rattle when I would close the drivers door. I finally took off the door panel earlier and found that the plastic film that was installed on the inner door skin was the cause of the vibration. The film was vibrating against a bolt head inside the door. I ended up putting a dab of black rtv on the plastic where it was coming in contact with the bolt head and that took care of the issue. So hopefully this info is helpful to someone with the same noise that I was dealing with.
