Eibach Stage 1 Lift for SR Lightnings coming soon!!
fluiddynamics
'24 Lightning Pro ; '23 Mach-E GT Performance ; '22 Maverick Hybrid
Construction
I am fortunate enough to live very close to the Eibach headquarters here in SoCal, and they took my truck for a week to develop a lift for the Standard Range vehicles
Ended up with 3" lift up front, and just over 1/2" in the back.
I am running 295/70/18 BFG KO3's on 18x9 Fuel Rebel wheels with a +1mm offset
There is rubbing on the bumper, but it was easily solved by just a bit of trimming, and a tiny bit of trimming to the crash bars as well, but overall I am very happy with the look
Ford F-150 Lightning Eibach Stage 1 Lift for SR Lightnings coming soon!! PXL_20241123_002501034
AZT9
Peoria, AZ
Didn’t realize that the stage one kit they have now was only for the ER models. Stance looks killer! Also the slight lift in the rear appears to correct the camber issue when going to larger tires. 🤙🏼
fluiddynamics
fluiddynamics
Construction
There is quite a difference in weights between the 2 battery types - hence the difference they developed, otherwise the ER kit would be too "stiff"
Whammy Bar
I have the ER kit and feel its a little too stiff (if I'm allowed to nitpick). Id love to see how the slightly lighter springrate on the SR kit rides on the ER....
F150ROD
U.S. Navy Retired
You have rubbing? That is interesting.
I was running an 18x9.5 +20 same spec tires, no rubbing on Stage 1. Looks like 18x9 +0 will be a no go for me 😭
fluiddynamics
fluiddynamics
Construction
45 min with a cut-off wheel and no more rubbing.... can't tell at all unless you are really looking closely...
NOTE: I do live in SoCal so salt roads creating rust in the cut location is not a concern for me
F150ROD
U.S. Navy Retired
Same, but prefer not to cut, only other option would be to stick to 33’s and lower a bit through the shock.
fluiddynamics
fluiddynamics
Construction
It's less floaty for sure... its more stiff, but feels more like a truck now, and less like a Lincoln Town Car. I would not call it harsh at all.
Andrewbens
Modesto
Lightning
Mechanic
I might have to get a spring kit for my ER I’m rubbing the rear liner on my 35” raptor wheels and had to cut up my front bumper currently I’m on a 2.5” lift
LSUT1GER
Slidell, LA
Computer Engineer
Do you have the front camera on your Ford Raptor Grill? How much did it cost you to get the front light bar wrapped with tint? I want to do the same thing....wrap front light bar and replace the front grill with the Raptor one. Did you do it yourself? Your truck looks fantastic.
fluiddynamics
fluiddynamics
Construction
My PRO did not come with a camera, so I didn't have to cut it in
I don't know the exact cost for the light bar wrap.... they charged me $800 for that and black out all the lights front and rear....
LSUT1GER
Slidell, LA
Computer Engineer
Can you send a picture of the rear of your Lightning? Where do you get the Raptor grill? How much did you pay for it?
Ford Motor Company
Official Ford Account
Ford
F-150
That looks fantastic, David! What a stunning F-150 Lightning! Thanks for sharing.
EFG
Ed
software developer
Based on the comments here, I went into my local off road shop here in Central Florida and they called Eibach. This kit will be available retail in Feb 2025.
