Initial Range (showing less than 320)
TBA
CA
23 Lariat ER+Tow Tech & Max Tow; Anti Matter Blue
So got my extended range Lariat on Friday. Reset all settings to factory including the mileage/trip memory.
Since Friday, have driven it about 90 miles; only seeing a max range of 305 miles. I am in the Bay Area, California. Lowest overnight temp was 36F.
Is this range normal?
It will drop further. Winter. 36 degrees. And adjusting to your driving. Evenin summer, you aren't the EPA. So if you drive city, it may go higher. If you drive mostly highway it will be lower than EPA.
Yes, it's normal. And if the temp goes lower, so will your range.
Firestop
Firestop
d2blake
Tavistock, Ontario
2010 F150 FX4
Engineer/Contractor
The best range you will get is between 70F-80F. Expect 0.5% drop in range per degree below 70F.
BennyTheBeaver
2023 Lightning XLT ER
Yep, very normal.
