Largest size tire that can be installed on the 20" wheels?
VictorM
Victor
Western PA
F150 Lightning XLT ER
Experiential Knowledge Griot
i upgraded to the 20” wheels for my XLT ER and would like to ask what is the largest size tire that can be installed? I plan to level the truck with a two inch lift in front and may want to increase tire size on the 20” rims.
Sneakypetie78
Pete
Marina del Rey, CA
2013 F150 limited
General Contractor
I don't know that the answer is cut and dry. You might have to be the test case. Wheel offset, and lift all come into play as far as clearances.
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Tire & Wheel Specialists
If you are planning on upgrading to the 20" XLT ER wheels and adding a 2 inch leveling kit in the front you would be able to comfortably fit a 275/65-20 (34.07) without experiencing any rubbing or having to do any fender modifications. A 285/65-20 (34.5) could also work, however you could run into some slight rubbing with the wheel fully locked.
Tons of options in either size!
VictorM
VictorM
Victor
Western PA
Discount Tire comparison chart indicates a +2.1 mph difference on the speedometer. Should I worry about calibrating? I assume the miles left guess-o-meter would be…lower?
Discount Tire
Arizona, USA
discountti.re
All Things FORD
Since the change is around 3% I wouldn't worry and would say that most individuals don't calibrate when moving up within this percentage. If there is a way to calibrate for the new size though, it's something to consider if accuracy is important to you.
I'm not sure how the estimated miles function works on the L, but if it's driven by the tire diameter, then it would be lower.
RedLightning86
Wisconsin Dells
can change odometer/range meter for the new tire diameter in FORSCAN
BennyEV
Benny
Charlotte NC
2023 Ford F150 Lightning
US Army
BennyEV
Benny
Charlotte NC
US Army
I already have a 275/60R/20 that came with my XLT ER from dealership, but I want to maintain the 60R but increase the width to 285, is this practicable, with reference to rubbing??
Alternatively I was thinking about going with a 285/45/22 or 285/55/22, what's your advice on that please
Discount Tire
Arizona, USA
discountti.re
All Things FORD
A 285/60R20 is a solid fit with no rubbing. You would be increasing the section width by just 10mm. A 285/50R22 would be as close to the factory overall rolling diameter and a 285/45R22 would be shorter. Keep in mind the shorter sidewall would stiffen the ride a bit.
