Lightning Side Step Mounting Locations vs ICE F-150
brtnstrns
Seattle
2024 Lightning Platinum; 2022 Polestar 2 LRDM
Does the Lightning use the same mounting points for side steps/running boards as the Super Crew ICE F-150s?
My assumption is that any side steps made for SC ICE F-150s will bolt right on to Lightnings as well, but just figured I'd see if anyone can verify that before I waste money for no reason...
Thanks!
BennyTheBeaver
2023 Lightning XLT ER
Yes.
On the Pro I had, I put on ICE take offs (no lights), and had no issues.
The exception being retractable running boards due to the motor mounts and locations. They still work, but it's not plug and play (or wasn't when I last looked in to it).
butterfb
Brett
Orlando, FL
2023 Lightning
Senior Support Engineer
Good to hear, i have through about removing my step sides and upgrading to the Tremor or Raptor ones.
Mcfly
Billy
Socal
23 Pro SR
Realtor
I have the raptor steps on mine. Bolted right up same as the stock steps.
derelict
XLT ER
I bought aftermarket ICE side steps for mine and they bolted up perfectly
From what I have seen the only concern is with some steps hitting the plastic tubs on either side of the frame, or a particularly large motor or mount contacting a wiring bundle or connector.
This was only for aftermarket powered steps.
I cannot see how any fixed steps would have this issue and I to have some ICE F150 steps mounted and they went on perfectly.
