Lightning to Mach-e Charging
Truaz
Phoenix, AZ
2023 F150 Lightning XLT-ER
IT Engineer
I'm trying to use the Portable Ford Charger to charge a Mach-e from my Lightning - XLT. The adapter states to limit Amperage to 24 amps and I thought this was a setting on the Lightning but I don't see anything. I checked on the Mach-e for input limit and again nothing there and the Ford charger itself doesn't appear to have any kind of way to adjust the amps.
So my question is this, am I missing a setting on either the Lightning, Mach-e or charger to adjust this or as a last resort is there a portable charger you can recommend that is either limited to 24 amps or can be adjusted to 24 amps.
Whammy Bar
Reliable - 1971 F100; Unreliable - 2022⚡Lariat ER
The Ford Mobile charger should stay just under the threshold that trips the pro power breaker if I'm not mistaken.
There is no setting to control/limit rate.
You have to use the mobile charger that came with the Lightning, not the one that came with the Mach-E (or at least switch plugs).
There is no control of the charging rates in either vehicle nor on the charger itself.
I think @RickLightning has mentioned this before. IIRC the mobile charger that comes with the Lightning is a 30A charger that allows it to use the 30A bed outlet. The charger that came with the Mach-E is 32A and would trip the ProPower.
And agreeing with @Firn - the charger is the same, but there is something in each plug that tells the charger either 120V (so 12A max) or 240V (30 or 32A max). Again, going off memory here.
Truaz
Truaz
Phoenix, AZ
IT Engineer
Ya, I have that and it trips the lightning saying max capacity of the bed outlets was exceeded.
Truaz
Truaz
Phoenix, AZ
IT Engineer
I didn't realize the portable chargers were different. I'm sure the ones I have are for the Mach-e, is there a specific part number for the Lightning charger?
I believe it's the plug-in dongle that's different, see post 4. Those are likely different part numbers, not the charger.
That jives with my memory.
Iirc the Lightning plug has an orange or yellow ring on it to indicate the lower 30a charge rate.
[Clap]
Ford F-150 Lightning Lightning to Mach-e Charging 1000002481
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Truaz
Truaz
Phoenix, AZ
IT Engineer
Ah, perfect. Thank you!
And a short video (<4 min) that shows close-up of the two connectors/adapters and manufacturer part numbers. Have to watch on YT.
