djwildstar
- First Name
- Guy
- Mar 14, 2023
- Atlanta, GA
- 2023 Lightning Lariat ER, 2023 Mach-E GTPE
- Occupation
- Information Security
For daily charging, you should ideally have something better than the Ford Mobile Connector. As a daily charger, it has a number of drawbacks:
I'm not terribly fond of the Ford Mobile Connector as a mobile charger. I personally use a J+ Booster2 for my mobile charger, because it offers adjustable charging current up to 40A and multiple socket adapters. Other folks have reported good success with the Tesla Mobile Connector, it's plug adapter kit, and a TeslaTap charging adapter -- I decided not to go that route because there's no way to adjust the charging current: Tesla cars allow you to do this from the car's screens, while Ford doesn't.
- It seems intended to keep on your truck, for occasional use on the road, and I have heard several people report that it eventually fails when used as a daily charging solution.
- It has multiple possible weaknesses, including the outlet and the connections at either end of the adapter cord; these connections can overheat causing the charger to reduce power or fail to charge.
- The mobile charger delivers a maximum of 30A at 240V (7.2kW) even when plugged into a NEMA 14-50 outlet on a 50A circuit (which can safely deliver up to 40A, 9.6kW).
