Ford Mobile Charger at Campsite 30amp
james_carey
James
Brentwood
2022 Ford F-150 Lightning
Contractor
Have you personally seen the 12 Amp limitation on a TT30 using a TT-30 to 14-50 adapter?
I was limited to 12 amps when I tried the Amproad iFlow in this configuration and never bothered to try another charger. @hikinbengal is saying that they get higher amperage using the J+ Booster and I'm wondering if I should try another EVSE.
That additional 1.4 kW would be helpful for charging at the cabin, especially in the winter.
Hmmmmm...... so now I am wondering if the J+ Booster is a better solution than the Amproad iFlow? Any thoughts? Features and benefits of one over the other?
jimfigler
Orchard park, NY
You should never try to pull 50 amps from a 30amp socket! And especially this corroded socket!
To charge from a 30amp outlet you should buy the SplitVolt (or similar) 24 amp charger. I use that and it works nicely. Charges at about 5.5 kW so much faster than the 1.4kW you get with the 112A @ 120V charger.
That is spider infested not corroded :p
vandy1981
Tennessee
Plumber
I'm not convinced that they're actually getting more than 12 amps on a 120v circuit so it may not be worth paying the extra money for a J+ Booster for that reason.
The J+ Booster is a very well-built and likely safer unit, though, as demonstrated by @tommolog:
Amps
Mid-Atlantic
Bolt
Any thoughts?
See if your usual campgrounds have 240V power anywhere available for you to use to charge your truck. If so, use the Amproad and start low (10A) and work up gradually if the receptacles look anything as nasty as that TT-30 in your picture. o_O
See if your usual campgrounds have 240V power anywhere available for you to use to charge your truck. If so, use the Amproad and start low (10A) and work up gradually if the receptacles look anything like that TT-30 in your picture. o_O
Repeat….TT30 is a 120V receptacle.
Amps
Mid-Atlantic
Bolt
Thanks, I’m aware of that. They need to find Volts not Amps to get around the truck’s limitation on 120V charging. That’s why I suggested to contact their usual campgrounds to see if any 240V receptacles are available. They ain’t going nowhere for a couple days with a TT-30/Level 1 charging.
xwing
Jeff
Okeana, OH
2023 F-150 Lightning
I use the AmpRoad charger in my garage as my daily charger. Works great and I charge at 40 amps (9.6kv).
