Moved to 2023 Model Year
Nick503955
Nick
San Diego, CA
2023 Ford Lightning Lariat, 2021 Tesla Model Y
Mine also changed to Avalanche.
Here's the worst case scenario for the price increase as I see it:
Ford F-150 Lightning Moved to 2023 Model Year 1662046111951
Looks like there is some price consideration based on this table:
Ford F-150 Lightning Moved to 2023 Model Year 1662055472603
bewbie
NYC
Just called my dealer to have the scale delete, think he said it went from priority code 99 to 10.
Are the scales known to have caused delays?
bewbie
NYC
@TaxmanHog i inquired about removing the scales and this was his response:
“You would not be able to get a 511A at all. You would most likely need to remove the onboard to get it built anytime soon, I just checked it wont even let me move forward at all until I remove that.”
my question now is if the reason for my order not being processed was because of this the whole time.
what would I be losing with the 511a package.
bewbie
NYC
They are currently not an option
On-Board Scales and Smart Hitch Removal
-$650
So that should be deleted automatically with MY23 while keeping the other features 511a offers?
They can start the build configuration 511A (ER Battery and all the related features) but can not send it to factory until the Deletion code to remove the scales has been input, then the configuration is build-able
They could start with a 510A SR, add what ever options you want on top of that like Tow Tech, with exception of scales which shows the reminder that the WBDO build will require the code to delete the scales
Ford F-150 Lightning Moved to 2023 Model Year 1662062897061
Trick
NJ
4runner
I would call the dealer, mine was not checked. Once he made the change it is now priority 10 and get the above confirmation from Ford
Oregonal
Al
MYLR, Bolt EUV
Meh
Did your color automatically adjust to Avalanche, or have you selected another color?
I was told a month or so ago that SQM was NLA so I chose AMB. From what I can tell that’s what it still says on my order..but please let me know if your information says otherwise.
FordLightningMan
Upstate New York
F150
If the original estimate was 15,000 MY22 trucks and we are seeing some slip into MY23, I wonder what they actually ended up able to produce? It seems like a good majority of the MY22 orders were produced, so maybe about 12,000 get produced in the 6ish month MY22 run?
bewbie
NYC
My dealer is saying He can’t do anything but select the 510 package which would make me lose the standard battery. He doesn’t see how he can delete just the scales.
Trick
NJ
4runner
Mine is the extended range 511 A. Scales are part of the tow tech package which is standard on the extended range. so they have to be removed
