No cabin heat Fixed post #34
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
Today my cabin heater suddenly stopped working. The blower works but only blows cold air.
I read that there was a recall (cold solder joint, 7/23 - 8/23, it mine was built 9/23.
Does anyone know anything about this?
I have heard of several people talk about the coolant pump, or coolant circulation pump failing. Sounds like it’s probably just a 12 V water pump.
Joe Dablock
Joseph
Stewartstown Pa. 17363
We shall see. I will call the dealer today!
Aguay
Albert
Dieppe,nb,Canada
2022 Ford Lightning Lariat eR
Management
I was away for the weekend and just jumped in to my truck this morning and zero heat. I’m thinking it’s a software thing?? Makes no sense
Joe Dablock
Joseph
My exact scenario, some on forum say coolant pump. I will call dealer this morning. Bummer!
Aguay
Albert
Dieppe,nb,Canada
Management
I called my dealer and the service guy is seeing codes came up on it when I started truck this morning. So will drop it off and they will provide a rental for me at minimum costs and will try to get it in as quick as they can. No heat is a safety issue so hopefully they can figure it out and replace parts and or update system.
but my guess is a software issue
BSEE SPARKY
Derek
Southern Indiana
2023 Lightning Lariat ER, MAX TOW, Power Running Boards
I have never had an issue with heat with truck in run mode. In Acc mode, there has been a couple of times where it did not get warm. However I don't think that has ever happened when I precondition truck using app.
Accessory mode IS NOT the same as remote start or departure timed pre-conditioning.
The HVB contactors are open in accessory mode, not transmitting energy to the 400v systems like the heater PTC, AC compressor or traction motors.
YellowstoneLightning
Torrey
Montana
2023 Lightning Lariat Extended Range
The heat went out in my truck in January in Montana ? Mine turned out to be the heater unit itself. It took a while to get an appointment, but it only took the dealer about a week to diagnose and replace it. I hope you can get this resolved soon, but just be glad this happened in April and not January!
locks66
Timothy
2022 Lightning Lariat
I have issues with my heat right now. Works for a bit, doesn't ever blow that much. Then after a longer drive the other day was only cold error. I have an error code showing for a damper with an ODB scanner so it goes in tomorrow
So update on my story. Took it in assuming it was a simple damper. I had a longer drive where the heat just stopped working. Came back the next day.
Ford dealer has no idea what the issue is but did verify the complaint. So now I am waiting for ford corporate to help the dealer rectify the problem. Luckily got a loaner.
Still wish the dealers would provide an EV loaner for EV drivers
Montecarlossfan
Connecticut
2023 Azure Gray XLT Lightning
Programmer
Worst case in a “I need to get the truck home” scenario , a small space heater would work with all of the onboard power we have
Joe Dablock
Joseph
You know what they say! Desperate people do desperate things!
Firn
23 Pro ER
I would recomend caution with just using a space heater.
The heater is necessary for the battery in cooler temps.
Beyond that if you don't have heat it could be an issue with the whole coolant system, meaning it could affect heating AND cooling the battery.
Exactly, If the root issue is a broken circulator pump, then battery cooling or warming is impacted, driving and charging in extreme temps could be hazardous to the battery pack.
Aguay
Albert
Dieppe,nb,Canada
Management
Well after a few days at dealership, corroded wire under Frunk . Not covered by Ford over the 3/60km warranty ( Canada). Corrosion is not covered. A failed part but not corrosion. $500cnd to fix ( all labour and a few dollars for a wire kit)
picking it up tomorrow
