No cabin heat
NCevGuyF150
North Carolina
22 Ford lightning
Repair technician
Today my cabin heater suddenly stopped working. The blower works but only blows cold air.
I read that there was a recall (cold solder joint, 7/23 - 8/23, it mine was built 9/23.
Does anyone know anything about this?
I have heard of several people talk about the coolant pump, or coolant circulation pump failing. Sounds like it’s probably just a 12 V water pump.
Aguay
Albert
Dieppe,nb,Canada
2022 Ford Lightning Lariat eR
Management
I was away for the weekend and just jumped in to my truck this morning and zero heat. I’m thinking it’s a software thing?? Makes no sense
Joe Dablock
Stewartstown Pa. 17363
My exact scenario, some on forum say coolant pump. I will call dealer this morning. Bummer!
Aguay
Albert
Dieppe,nb,Canada
Management
I called my dealer and the service guy is seeing codes came up on it when I started truck this morning. So will drop it off and they will provide a rental for me at minimum costs and will try to get it in as quick as they can. No heat is a safety issue so hopefully they can figure it out and replace parts and or update system.
but my guess is a software issue
BSEE SPARKY
Derek
2023 Lightning Lariat
I have never had an issue with heat with truck in run mode. In Acc mode, there has been a couple of times where it did not get warm. However I don't think that has ever happened when I precondition truck using app.
Accessory mode IS NOT the same as remote start or departure timed pre-conditioning.
The HVB contactors are open in accessory mode, not transmitting energy to the 400v systems like the heater PTC, AC compressor or traction motors.
YellowstoneLightning
Torrey
Montana
2023 Lightning Lariat Extended Range
The heat went out in my truck in January in Montana 🥶 Mine turned out to be the heater unit itself. It took a while to get an appointment, but it only took the dealer about a week to diagnose and replace it. I hope you can get this resolved soon, but just be glad this happened in April and not January!
