So... zombie techs?This should be left to killed service tech with access to lift and oil pumping equipment.
Are the manuals on this site? I love learning more about my lightning.When I pulled the snap shots, they were from my local static copy of the manuals downloaded months ago, so, I dialed up FORD.COM, logged in and pulled the current version of the manual based on my VIN, this section is basically the same for the 2022 MY.
No, but you can access the OWNERS MANUAL directly from Ford.com, there are HTML and PDF versions to peruse or download.Are the manuals on this site? I love learning more about my lightning.
If you still have pictures please post the filter location and fill plugI have drained and filled my own drive unit fluid. I did it at about 10K miles. Even though the service interval doesn't call for service until 150K, whenever gears are breaking in, there will always be some degree of wear material imparted into the fluid, so just to be prudent, I checked the service manual for the spec (just a standard ULV transmission fluid) and used a fluid extraction pump to remove the old fluid (since after inspecting the fluid, I had no doubts that the filters and filter screens were probably barely contaminated. I then filled with fresh ULV fluid up to proper lefel (up to the fill port).
Super straightforward and now I feel 100% confident in running it all the way to 100K+.
If you guys are interested, I can post pictures and more if you'd like.
Also, as for brake fluid service, any decent bi-directional scanner can execute the bleed function.
I don't have my shop manual PDF readily accessible right now for detailed diagrams, but I can leave you with some of the pictures I took while doing the service. I've also included a picture of the box of one of the screw on filters so you can see the part number. (both motors use the same filter)If you still have pictures please post the filter location and fill plug
I'm a fan of Amsoil but there are others out there too. High Performance Lubricants comes to mind.Ur awesome thanks!!
I was thinking about putting the AMSOIL UL @ $22 a quart like 10 quarts
any thoughts?
42k miles on ‘23 and just now only back motor working and derated to 56% after a 40 min update
You’re not going to fix the 56% issue by doing an oil change. It is a programming issue with that update and your truck will be fine after a drive or two and/or being off for a while.Ur awesome thanks!!
any thoughts?
https://www.hplubricants.com/category/automotive-lubricants/I'm a fan of Amsoil but there are others out there too. High Performance Lubricants comes to mind.
Depending on climate, I would look at viscosity of the various options and maybe look to see if one is on the lower side to maybe eek out a bit of an efficiency improvement. With HPL being a blender I debated reaching out to them to see if they had thoughts on a custom blend focused on efficiency.
You realize it doesn't need to be changed until 10 years or 150K miles.Does anyone have the torque spec for the oil pan bolts?
Thank you! Yeah, I know. But I have 80k now in 2.5years. Im getting nervous about wear particles. I need to get a copy of the shop manual!You realize it doesn't need to be changed until 10 years or 150K miles.
But otherwise it's in the workshop manual, need to reseal the pan with RTV, then :
5. Install the transmission oil pan and the bolts.
Torque: 97 lb.in (11 Nm)
