Power down timer
Farmford42
WA
69 Bronco
Farmer
I seem to be missing the power down timer setting. Anyone else having this issue?
picture soon
Should be under Vehicle settings.
Ford F-150 Lightning Power down timer 1697126017345
Farmford42
Farmford42
WA
69 Bronco
Farmer
Here was the screen this morning
Ford F-150 Lightning Power down timer IMG_3897
Ford F-150 Lightning Power down timer IMG_3898
sd25
NJ
Acura MDX, F-150 Lightning Lariat ER, Rivian R1T
@Farmford42
Have you applied any configuration changes recently thru FORSCAN?
I know there was a FORSCAN code on the Mach-E forums to remove the power down timer.
I was actually considering it, since I'm frequently in the truck "idling" and find that timer annoying.
Look at Pro Power onboard for interactions about the power down timer.
Farmford42
Farmford42
WA
69 Bronco
Farmer
@Farmford42
I haven’t played with FORSCAN yet. I did. Not see a recent update. I use the power down timer all the time so it’s odd.
Farmford42
Farmford42
WA
69 Bronco
Farmer
So it’s just where it was af the end of the day. If I did not take a picture I would have thought I was crazy
Farmford42
Farmford42
WA
69 Bronco
Farmer
So, it looks like the power up 6.1.0 was downloading this morning, and then installed in the evening. Very odd, but glad its not gone!
Howard_Scott_Warshaw
2022 Lariat ER, rapid red
Soooo mine disappeared this afternoon. The toggle is just gone.
No recent updates to the ap or the truck that I'm aware of.
Ford F-150 Lightning Power down timer 20240728_150837
Nikola 369
Pella, IA
2022 F150 lightning Lariat SR
Sales Engineer
I’m not sure about this, but I think Ford may have started sending updates that don’t show on our screens. I have been checking LVB percent only once each morning over the last couple months. Some mornings ( most mornings ) it’s only down 10-15 %, about once a week or so, it’s way down. Once it was down around 40%………….. The keys aren’t near truck and I have nothing plugged in or anything that is waking truck up. The last formal update was 6ch audio that came in beginning of May. So……..this is why I wonder if they are rolling updates that don’t show on our screens? Makes one wonder.
I'm at the same last update as you guys on my 2022 Lariat-ER.
I'm still seeing the shut down timer on/off switch.
