If you have current software on the truck, you can set Pro Power to run when the truck is off; thus, it's not cumbersome.
This is an AS BUILT feature of model year 2024 Lightnings, the rest of us wait for an OTA that back loads this and many other enhancements you're enjoying.
Lorincz
Joe
Mountain View, CA
2023 Ford F150 Lightning Platinum
Software Engineer
I just checked, and my truck's SYNC 4 Software Version is 23151_PRODUCT Revision 902. I'm not sure how this compares to the newest version. If I had to guess, this version seems quite outdated, as my truck has struggled with automatic updates since the beginning.
Moreover, my dealer doesn’t seem knowledgeable enough to update it either. The navigation feature is missing from the menu, even though the FordPass app indicates an active subscription until April 2026. The dealership suggested waiting for the next over-the-air update to see if it resolves the issue, which isn’t the solution I was expecting.
mrau
23 Lariat⚡ER
My 23 Lariat has Sync version 24127 And Revision 1270.
Believe it is one of the more recent versions out.
Lorincz
Joe
Mountain View, CA
Software Engineer
Thanks, @mrau! Your version definitely looks more up-to-date. I'm getting "No updates available at this time for your vehicle."
danvilla
2024 F-150 Lightning Lariat
When you checked, the heating element wasn’t powered. 400W would be approximately the power requirement of the motor.
This makes sense. When I’m feeling curious, I’ll bust it out again and see if I can catch the peak power draw on the app. Thanks for pointing this out. A bit obvious in hindsight.
Comarley
Craig
2023 XLT ER
Here in Virginia we use a new technology called a clothesline, and sunlight. I know you guys don't get any sunlight, so this is the next best option.
Some people use the sunlight to charge a battery to power their dryer in a power outage. Glad to see you’ve cut out the middleman.
