riceilove
EC
Denver, CO
Just had to drop my truck off for the second time now with this issue, confirmed to again be a battery module failure and an estimated two weeks for a new one to arrive. Pretty bummed that I was right about it being a battery issue again.
Regarding lemon laws, does it backdate to the first time I experienced this issue or is it the present time. Asking, because I'm less than a month past two years of ownership and only a couple thousand miles past 20,000. Not really sure about the process to make it a lemon or what comes with it, but looking for opinions/options (if I even qualify) if this is another lengthy wait time for repair. Thanks!
It depends on your state. E.g. Colorado has a 24+6 months law where if the first time the issue occurred was within 24months or 20k (or 24k?) miles, you have up to 30 months from purchase date to file a lemon law buyback.
bordner42
Brendan
F-150 Lightning Pro
Bought in NJ and registered in Ohio if anyone has any experince
bordner42
Brendan
F-150 Lightning Pro
It usually adheres to the state you purchased in, so NJ in your case. My quick search says 2yr/24k miles.
Yeah I'm doing additional research and I'd be fairly upset if it was didn't qualify because I was 2 years + 2 days and 224 miles over.
Piquette
Trent
New Hampshire
2022 Lightning Lariat
Sorry to hear that you have also lost two battery modules in 24k miles. There are two issues here. First, you are out your truck for at least 2 weeks, and second, there are still 7 other original battery modules in your truck, any of which could (and probably will) go bad at any time. I have become leery of taking my truck far from home for this reason. Meanwhile Ford is stalling on my request for a buy back. 😟
bordner42
Brendan
F-150 Lightning Pro
Could only be 6 original battery modules after this! They didn't say which failed, so might not even be the prior replacement one that failed.
GoodSam
Good
occupying space
there are 9 battery modules, so could be 7 or 8 original modules still left after repair. There has been one report of someone having 3 modules replaced (see my tracking spreadsheet in my signature below). Speaking of which, what is your Build Month/Year shown on your driver's door sticker at the top? Early 2022's seem to have the worse luck, but even 2024's have been bit by this long time delay repair. If the battery module replacements could be done in a few days, instead of weeks, the pain would be less severe for everyone, including Ford for fewer lemon buybacks. @Ford Motor Company
Wonko
Erick
Atlanta
2023 F-150 Lightning Platinum
Have you looked at how many of the failed modules are related to battery cooling system failures? Anecdotally I have seen several cases where either a diverter valve or a heater assembly (like my case) was correlated with bad modules. Presumably the cooling system is necessary, especially while charging, so it stands to reason that cooling system failures could be at the root of at least some of the module failures.
GoodSam
Good
occupying space
Yes, that would make sense. The 96 battery cells, made up of either 4 (SR) or 5 (ER) pouches, expansion and contraction, due to charging and temperature variations, are being stressed. Also, @MickeyAO implied that testing showed bigger "depth of charge"s (say, 10-100% vs 50-70%) were more stressing on the batteries. Normally, the cooling & heating system should minimize the temperature factor.
Wonko
Erick
Atlanta
If you think about the concept of people who have had multiple modules fail, you would think Ford would have a 6 Sigma team all over data collection trying to get to root cause on these failures. The numbers of just casually voluntarily reported failures to a Google sheet on a forum, which is probably a fraction of actual failures, out of the fairly small population of vehicles in the field suggest they have a pretty big issue on their hands.
