Seatbelt Warning
TNVolFan
RG
Kentucky
2023 F150 Lightning XLT Stanard Range
Wondering if anyone else has this issue...
My 23 XLT will randomly throw a seatbelt warning - either front passanger or rear passanger. Then the next time I get in the truck, it will be gone. Days or even weeks will pass and another error message is given, but only until the next time I start the truck.
Any ideas?
Pull up the seatbelt display on the center cluster, and watch for which seat is giving your truck grief, might be a poorly seated connector barely making/breaking contact
sr3jan
Jeff
Atlanta, GA
23 Lariat
I am no help with your seatbelt issue but instead came here to say GO VOLS! #vfl
TNVolFan
TNVolFan
RG
Kentucky
In the bigger scheme of things Vol Nation ranks above seatbelt issues!
Ford Motor Company
Official Ford Account
F-150 Lightning
Any ideas?
We would be happy to look into this seatbelt concern on our end for you. Please send over a private message with your VIN to get started.
EdRudy
Ed
Springfield, VA
Any ideas?
Are you carrying any heavy items in the seat when this happens?
TNVolFan
TNVolFan
RG
Kentucky
No and sometimes it says front passanger seatbelt and other times rear passanger. Going to get it to Ford next week.
Kilimmaic
Ford F-150
It could be a glitch in the seatbelt sensor system. Sometimes these things can be a bit tricky to pinpoint. Have you considered taking it in for a car servicing? Pay attention to servicing stop. A professional mechanic might be able to run diagnostics and identify the root cause of the problem. It's always better to address these issues sooner rather than later to prevent any potential safety concerns down the road.
F150 Lightning XLT
On my ‘24 XLT with 7k miles I’m getting a driver seatbelt warning sound when seatbelt is engaged and dash console shows a green checkmark that the seatbelt is engaged.
Problem occurs intermittently.
Problem goes away after 10-15 seconds.
mrau
23 Lariat⚡ER
Might try turning the seatbelt chime off. Can turn back on after a bit to see if it still occurs.
From page 54 of the Owner's Manual.
Ford F-150 Lightning Seatbelt Warning Screenshot 2025-01-15 at 5.30.08 PM
F150 Lightning XLT
Thanks. I did not succeed in turning off the seatbelt sound. May have been unclicking etc at not quite the right speed. I only tried it once, but I need to get the truck into service for some other stuff so booked it in for this as well.
