GoodSam
Is the HVAC turned off? Also, center screen can be turned off, but instrument panel does stay on, but that should be minimal. Is the weather cold or hot enough to have the HV battery coolant pump for the cooling/heating system running? I guess it would be nice to be plugged in to not worry so much about power use. I was weekend camping in 100F heat with a Bodega T50 refrigerator running inside the cab with the A/C running at 80F setting, but I did not think about that, perhaps, the HV battery may have been trying to stay at a cooler temperature as well. Battery capacity level dropped, but I thought all the power use was by the air conditioning.Think coolant pump, computers, screens, lights, etc. If I manually shut the lights off, it seems to pull about 0.4-0.5 kW from the HV battery with nothing plugged into the outlets.
