SSM 53236 "Trailer Brake Module Fault" Message in IPC
Mike G
N. AL, USA
17 Dec 24
SSM 53236 2021-2023 F-150 Non-Lightning, 2022-2024 F-150 Lightning/Expedition/Navigator, 2024 Ranger – "Trailer Brake Module Fault" Message Displayed In IPC And DTCs U0137 And/Or U0252 In The BCM, IPC And/Or PSCM
Some 2021-2023 F-150 non-Lightning, 2022-2024 F-150 Lightning/Expedition/Navigator, and 2024 Ranger vehicles may exhibit a "trailer brake module fault" message in the instrument panel cluster (IPC) with diagnostic trouble codes (DTCs) U0137 and/or U0252 stored in the body control module (BCM), IPC and/or power steering control module (PSCM). This may be due to the trailer module (TRM) not communicating in the controller area network (CAN). Replacement of the module will not correct the condition. To correct this condition, disconnect the 12-volt vehicle battery and the TRM connectors and let the vehicle sit for at least 5 minutes. After 5 minutes, reconnect the 12-volt vehicle battery and TRM connectors and reprogram the TRM to the latest software level using the Ford Diagnosis and Repair System (FDRS) scan tool. For claiming, use causal part number 19H332 and applicable labor times found in Section 10 of the Service Labor Time Standards (SLTS) Manual. If symptoms continue, refer to Workshop Manual, Section 418-00A Electrical Distribution > Controller Area Network (CAN) Module Communications Network > Diagnostic and Testing.
Ford Motor Company
Official Ford Account
F-150 Lightning
17 Dec 24
Hello, could you please send us a message with your VIN and mileage so I can take a further look into your brake fault concerns?
:clap:
vorguy
Harry
Sacramento, CA
'24 Lightning Lariat, '03 F-250 6.0
Airport maintenance
I had the Trailer Brake Module Fault appear on Thanksgiving morning last month along with Blind Spot Assist System Fault and Front Camera Visibility Low. The blinkers would also sound like they were blinking rapidly but actually were not. I took the truck to Elk Grove Ford and was told the trailer brake module needs to be replaced and I can have the truck back while awaiting parts. We set an appointment for 1 week later. I picked up the truck and all faults are gone, which lends credence to the SSM.
I received a call from the dealer a week later stating the part is coming from the manufacturer and will take longer. It's been two weeks now and have not heard a peep. I had a similar problem with the dealer getting parts to fix a frunk/cab pro power issue. Ford should do better with logistical support.
VIN 1FT6W5L75RWGxxxxx
I apologize for the rant...
Mike G
Mike G
N. AL, USA
The holidays can be stressful, I know...
Ford F-150 Lightning SSM 53236 "Trailer Brake Module Fault" Message in IPC Awkward
