Table saw & Vacuum?
Mach_5
Burnaby, BC
2024 F150 Lightning
Carpentry
Hi all, I recently leased a 2024 Lighthing XLT (standard range), and had an opportunity to try the pro power onboard for a small job. The bed plug ran a small 8-1/4" dewalt table saw no problem but if I tried to run a shop vac simultaneously the breaker got tripped. The vacuum seemed to run fine on it's own, and it didn't matter if one was plugged into the bed and the other run off the frunk plug. Anyone else have success running both a table saw and vacuum/dust extractor combo?
Mach_5
Mach_5
Burnaby, BC
2024 F150 Lightning
Carpentry
I can plug them both in on the same home outlet yes. I'm guessing the answer might just be "try a smaller vacuum/dust extractor or one with less draw". Haven't done much testing/research on the pro-power limits as yet (and rarely would ever need this set up), but just curious as to others experiences.
Heliian
I think you'll find that it would work on a household service. Inverters are much more sensitive to peak loading.
Heliian
Ya, it's the startup draw. You'll most likely need to put a soft start cap on one of them.
rickersondon
Don
Manassas VA
Ford lighting 2023
The also have a 240 to 110 adapter the should use a separate inverter with a higher amperage.
CyclopsThere
Portland
2023 XLT
IMO the full power pro power is the killer app for the truck. If you didn't buy a truck with the 9.6 kW, I would not hesitate to upgrade it so it has full power. Those of you looking to buy, make sure you get this upgrade.
Yes, probably overloaded the 2.4kW on-board power.
It was an option to have 9.6kW on my 2023 Pro (from my sticker) not standard:
OPTIONAL EQUIPMENT/OTHER
.18" MACH BLACK HIGH GLOSS WHL
.ZERO EMISSIONS VEHICLE
.275/65R18 BSW ALL-TERRAIN TIR
.ELECTRIC DRIVE E-LOCK RR AXLE
8250# GVWR PACKAGE
FRONT LICENSE PLATE BRACKET NO CHARGE
TOW TECHNOLOGY PACKAGE 1,950.00
.INTEGRATED TRAILER BRAKE CONT
PRO POWER ONBOARD - 9.6 KW 1,200.00
MAX TRAILER TOW PACKAGE 1,100.00
MIRROR MAN FOLD W/POWER GLASS
LED SIDE-MIRROR SPOTLIGHTS
ONBOARD SCALE/SMART HITCH RMVL - 650.00
MOBILE POWER CORD (120V/240V) 500.00
360-DEGREE CAMERA PACKAGE
From what I've read and seen on schematics:
Both the 240 and 120 outlets in the bed are on the same inverter that provides 7.2kW
The rest of the outlets have another inverter with 2.4kW
WIth Pro Power, would you just do this:
https://www.homedepot.com/p/DEK-3-ft-10-4-Heavy-Duty-Cord-240-Volt-30-Amp-Twist-Lock-
Adapter-for-Generator-Cord-ACC01M21/317183948
and then get 2) 30 amp legs at 120 volts AND the 2.4 kWh Funk plug
I
The table saw probably draws 15A, which leaves little left for the vac assuming it's a 2.4kW system.
https://www.homedepot.com/p/DEWALT-...h-Compact-Table-Saw-Stand-DWE7485WS/313820771
