- First Name
- CHRIS
- Dec 16, 2022
- alexandria virginia
- 2023 F-150 LIGHTNING, 2012 Nissan Leaf, 2015 Toyota Prius, 2000 HD 883 Sportster
- Occupation
- Patent Atty / Electrical Engineer
The T3 project is something to look forward to, if they come through with all the things they have been talking about, aerodynamics, lighter weight, etc.It's not a model year thing, as much as it is a next generation vehicle thing. T3 truck for example. That's why all the news says "new EVs".
Still wondering about the NACS thing being implemented on new EVs.
We'll probably still need to carry along adapters on long trips since many (most?) commercial charge stations don't have the NACS / Tesla plug and CCS has been rolled out already, still some out there with CHAdeMO too.
Then there is this for federally funded chargers as of 2023 which promotes/requires the CCS standard, but also allows for other types of connectors:
EV Charging Minimum Standards Rule
FHWA, with support from the Joint Office of Energy & Transportation, unveiled new national standards for federally funded EV chargers in February 2023. These new standards aim to ensure that charging is a predictable and reliable experience for EV drivers. This includes ensuring that drivers can easily find a charger, do not need multiple apps and/or accounts to charge, chargers work when drivers need them to, and are designed to be compatible in the future with forward-looking charging capabilities. The rule establishes minimum technical standards for charging stations, including required number of charging ports, connector types, power level, availability, payment methods, uptime/reliability, EV charger infrastructure network connectivity, and interoperability, among other standards and requirements.
https://www.transportation.gov/rural/ev/toolkit/ev-basics/charging-speeds
Number of Charging Ports
This final rule establishes a requirement for the number of ports at a charging station. Any time charging stations are installed there is a required minimum of 4 ports, notwithstanding the type of port (Direct Current Fast Charger (DCFC) or alternating current (AC) Level 2 or a combination of DCFC and AC Level 2). Additionally, in all instances when a DCFC charging station is installed along and designed to serve users of designated AFCs, there must be at least four network-connected DCFC charging ports.
Connector Types
This final rule establishes a requirement that each DCFC port must have a Combined Charging System (CCS) Type 1 connectors. This final rule also allows DCFC charging ports to have other non-proprietary connectors so long as each DCFC charging port is capable of charging a CCS-compliant vehicle.
https://www.federalregister.gov/doc...cle-infrastructure-standards-and-requirements
