Thought on our frigid 1,300 mile trip
CD4TNF
F150 Lightning ER
The rest of the trip range looks good and safe. I agree with your strategy better safe and charge more often than waiting for a tow.
The Miles City to Billings makes me the most nervous. At 1.2 mi/kWh that gives 137 miles of range from 97% to 10%. I would feel more comfortable charging up to 95% to 99% SOC to get thru that leg.
I used the Lightning calculator a owner on this forum made. You must get better than 1.2mi/kWh is how I am interpreting it.
https://lightningcalcs.pages.dev/?battery=131
During the trip, I usually glance at the dash mi/kWh and compare that to what I should ideally get. In this case, getting 1.2+mi/kWh on this segment is good. Seeing 1.1mi/kWh or less is going to need a backup stop.
I looked over PlugShare. Those two cities are the only ones with level 3 chargers. The backup is a level 2 in Custer. Meaning by Custer, you need to decide if you can make it. That's 62 miles between Custer and Billings. So the dash needs to read better than 49% or 77 miles at 1.2 mi/kWh. If it's not, stopping at Custer for an hour or two would make it.
The only other advice is what folks have already said. Driving slower at 55-65mph. If conditions are that bad, you might be driving that anyways.
I'm optimistic you can make it.
Now for my own experience. The lowest temp I've driven with the Lightning was 19F and I got 1.5mi/kWh. I drove through an active moderate snowstorm, plowed highway and got 1.6mi/kWh
husky10101
E Wa
So you were able to make that trip without supercharger access starting out at -41? If so, my trip should be a breeze.
Yes no supercharger access yet at that time.
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
Hey guys. OP here. Looks like the weather has really changed for the worse. Highs at 7 degrees and lows of -9. Does the Lariat ER really lose 50% range in these conditions or is it more like 30%. We will postpone our trip if we have to charge to 95 or 100% at each stop. Charger distances for the most frigid travel listed below. Thanks.
EV Connect Watertown to SC Sisseton, SD: 58 miles
SC Sisseton to SC Fargo: 89 miles
SC Fargo to SC Jamestown: 90 miles
SC Jamestown to SC Bismark: 102 miles (truck on overnight on L2 charger)
SC Bismark to SC Dickinson, SD: 97 miles
SC Dickinson to SC Glendive,MT: 96 miles
SC Glendive to SC Miles City: 77 miles
SC Miles City to SC Billings, MT 139 miles
Stick with your plan. You will learn a lot from this trip. I am not saying so you can suffer but you have done your homework and it will work. It is your choice. Good luck.
