Tire pressure adjustments for outside temps.
1Jetpilot
Jerry
Port Clinton, OH
2023 F150 Lightning Lariat ER
Retired Pilot
Why don't someone just tell us how to use the chart if the placarded tire PSI is 38 and your garage temp is 20? I get 40 PSI
inchman254
Collingwood, Ontario, Canada
F150 Lightning Lariat, Kia Telluride
I use 1 PSI per 10F difference between garage and outside. The actual temp of your garage doesn't matter... Only the difference.
"Cold" tire pressure means in the driving environment.
Unless you heat or cool your garage, this is totally unnecessary. Let's say that I check my tires at 8AM. Garage is 30 degrees. Outside is 20 degrees. I do the math, and fill my tires.
Now, I go for a drive at 2PM. Temp has risen to 50 degrees! Crap, I pull back in the garage and lower my tire pressure....
I do my tires on the first Saturday of each month. In the garage, without the sun hitting them. The only adjustment I make is going a pound or two higher as winter enters, and a pound or so lower as Spring comes.
With the inaccuracy of tire gauges, the reality is that you are plus or minus 2 to 4 pounds anyway.
Firn
Firn
23 Pro ER
You are essentially doing the same thing, just with less....science (not trying to imply your method is incorrect).
A good gauge should get you really close
