minirx7
What do you mean stop stating this as a base fact? I had the 2018 Nissan Leaf SL (it doenst have cooling but it does warm the battery in cold). Just running the car my stated range goes from 240km (actual summer range isa bout 215kms) down to about 120kms at best.I really wish people would stop stating this as a base fact. Yes, if you do not condition the cells, you can and will lose 50% or more of capacity (as demonstrated in my -30C cold crank testing). This is a real problem on EVs that use passive temperature management (Leaf, eGolf, and even the Soul with forced air cooling). When you move to active temperature management, you can really limit the losses with preconditioning.
It's no different in the losses of an ICE engine until you get it warmed up (which my Powertrain Engineers get on me about the how cold I run my current truck due to my limited driving).
I expect it to be slightly better with my 2021 Model S Refresh, but the cold does impact the battery (espeically in Canada), and running the heat (even with the heat pump) has major impact. Also highway speeds really draw the battery down. twice with my leaf i had to almost get towed because i didnt expect the battery to take a massive hit. Driving with more people also has a dramtic hit on range.
Curious, do you/ have you owned and driven an EV on a daily?
