Administrator
Administrator
Staff member
Purple State
F-150
Admin
Check out this F-150 Lightning Lariat build by Brian R.
Mods:
Custom fender flares (modified Bushwacker flares)
AMP Powerstep Xtreme Power Running Boards (Dual Motor AMP78152-01A)
Pace Edwards Matte Bedlocker Tonneau Cover (MBLF171) in Matte Finish
22" Carroll Shelby Gloss Black CS45 Wheels
Toyo Proxes ST III 305/45-22
Painted black grille
Tinted windows
* Factory Lariat tire/wheel combination weighed 74.6 lbs each, compared to 67.4 lbs for the above aftermarket wheels/tires combination.
Ford F-150 Lightning Lightning Lariat Build: Power Running Board Steps, Custom Fender Flares, Power Tonneau, Painted Grille, Wheels, Tires 291882539_10209486499596184_5632592562066827881_n (2)
Ford F-150 Lightning Lightning Lariat Build: Power Running Board Steps, Custom Fender Flares, Power Tonneau, Painted Grille, Wheels, Tires 292390895_10209487346297351_4275091969068432366_n
Ford F-150 Lightning Lightning Lariat Build: Power Running Board Steps, Custom Fender Flares, Power Tonneau, Painted Grille, Wheels, Tires 292561594_10209486499676186_5478086340754267217_n (1)
RavenYZF-R6
Denver
Tacoma
I’d love to hear if the power running boards were a standard install or if modifications were required. Really want them on my Pro.
Administrator
Administrator
Administrator
Staff member
Purple State
F-150
Admin
Owner says that they (AMP Powerstep Xtreme Dual Motor AMP78152-01A) fit right out of the box.
sotek2345
Engineering Manager
Are those wheels rated for the weight of the Lightning? I am really curious what the range impact is from the lack of aero on them.
beatle
Springfield, VA
You had me at powered running boards.
Looks like the wheels are load rated for 2500 lbs so they should be good for the Lightning:
https://www.holley.com/products/whe...rroll_shelby_wheels_cs45/parts/CS45-395512-CP
If you're comparing to a Lariat's stock 20" wheels, my guess is you'd be down to maybe 280-285. The wheel/tire package is lighter, but they have a larger contact patch and presumably have more rolling resistance. Maybe the running board delete will make up what would also be lost to the fender flares.
2000Firehawk
2022 Lightning Lariat ER
I’ll do a bit more research on the regular F150 forums, but wondering if these steps come out to a different step point than the attached boards. I very much dislike the attached standard ones on my Lightning. Would prefer if they came out further if not out and down for others who get in the truck.
LightningShow
MA
'22 Lariat ER
Product Development
Do the running boards have the integrated zone lighting?
Amp boards are great. I had them on my 2018. I liked them better than the stock boards on my current 2021 Lariat. They come down farther and project out more than the stock boards, or the factory power boards.
They do include some lights. You have to drill through the pinch seam on the bottom to mount them.
Rob G
Rob
Monmouth County NJ
GV60 Sport, Bronco BL Sasquatch, Taycan 4S
As always would love to know range impact. All the mods look great.
beatle
Springfield, VA
They look good, but not $2k Good, unless they increased range by like 5-10% :)
Agreed, I love them but they're a bit rich for my blood. I do think you'd get a few percentage points of range by using them, though.
chirocam
Cameron
Tampa, FL
4Runner --> Ford 150 Lightning Lariat, Agate Black
Chiropractic Physician
Those power running boards look SO MUCH BETTER than the stock ones.
RavenYZF-R6
Denver
Tacoma
I received 10% on boards so I jumped at $1,799+ tax. I figure on my pro I have 13k to play with to get to XLT level, without their shit I don’t care about like cloth and carpet. Only thing I’m missing is the front and rear light bars. The rest of the higher trims I can go without.
vandy1981
Tennessee
Plumber
I like the look but would miss the extra zone lighting that was built into the stock running boards. I wonder if there's away to incorporate additional lighting that uses that circuit.
