ZSC100
So, mr2urbo004 and I have been exploring what it would take to add the 240V,7.2kW inverter to the lightning to upgrade to the "Pro Power Onboard 9.6kW"
Ref: https://www.f150gen14.com/forum/threads/7-2-progen-missing.10245/page-2
I'm curious if anyone has done this or explored it for the Lightning? The truck I've used as an AB Config reference for all the OEM mods I've done has at some point caused my APIM to think I have it when I really don't. This causes a weird display on the Pro Power screen:
Last night was the first night we've been without grid power since I've had the truck almost a year. I hooked the truck up to my house to power fridge, lights, nat-gas continuous hot water, etc. I am suddenly wanting the 240V pro power to run my AC
Not an issue for me for heat as my furnace is nat-gas, but sleeping hot sucks. So, here is my window sticker.
2022 XLT SR EG 311A:
Here is the 2022 XLT SR EG 312A:
Is my terminology correct here in that we should be referencing this equipment as "Pro Power Onboard Standard" and "Pro Power Onboard 9.6kW" related to the Lightning, even though we are really only adding a 7.2kW,240V inverter to upgrade to the 9.6kW? My OCD is not compatible with Ford and terminology a lot of the times. Aside from any wires or coolant hookup it looks like only 2 parts are needed for this upgrade are:
The Inverter, $1,574.05:
Part #: NL3Z-14B227-B
https://parts.ford.com/shop/en/us/electrical/control-modules/hybrid-voltage-converter-p-nl3z14b227b
The Plug Panel, $284.70:
Part #: NL3Z-19A464-B
https://parts.ford.com/shop/en/us/e...ry-power-outlet-battery-charger-p-nl3z19a464b
jdmackes can you please post a pic of your window sticker so I can pull your AB and see how it is listed and check the module info.
