ZSC100
It appears to be Part #: NL3Z14290MDo we know the cable part #?
https://parts.ford.com/shop/en/us/e...ck-control-module-wiring-harness-p-nl3z14290m
I'm able to see this diagram on parts.ford.com, but for the life of me I can't figure out how to go from the base # 14289A to the actual part # NL3Z14290M. My parts guy at the dealer said he also doesn't know why they don't really make it easy to do this for owners on parts.ford.com, but once the dealer provided me the part # I could plug it in and see that the description does make sense:
Drive Motor Battery Pack Control Module Wiring Harness
Power Inverter #3. Single Phase Charger - 145"/3675MM Wheelbase.
I could try to figure out the coolant hoses this way too ,but I honestly think the coolant hoses can be done with normal automotive plumbing methods but will need an example vehicle to go by to know where they tee in. We need someone with this Pro Power Onboard 9.6kW to be able to reference, take pics, have their bed pulled off . Preferably a Pro or XLT.
I'm guessing the 7.2kW, 240V inverter is referred to as "Power Inverter #3", so I searched this and found this:
Part #: NL3Z7F120A
https://parts.ford.com/shop/en/us/engine/engine-cooling/engine-coolant-pipe-tube-p-nl3z7f120a
Part #: NL3Z8D121B
https://parts.ford.com/shop/en/us/engine/engine-cooling/engine-coolant-pipe-hose-inlet-p-nl3z8d121b
