Installing New Pro Power today
Is there a way to get the update without WiFi? (USB, serial, etc). I gave up on trying to get it connected. My main WiFi is too far away, but even when I took an old AP and put it right next to the charger, it would not connect (wouldn't show up in the router DHCP table).
No, wifi is the only way ...... do you have another mobile device with shareable hotspot functionality?
luebri
Neenah, WI
The charger worked flawlessly. First time I woke up to a fully charged vehicle. I did not hook to Wi-Fi, I may eventually try, but after it warms up in spring. LOL.
Fully charged as in 100% or fully charged as in charged to your preset Target charge %?
HOTAS
‘24 Lightning Flash, Tesla MY, Chevy Volt, PiPrius
Airbus Pilot
The electrical contractor is at my house right now installing the Pro Power Charger.
Nice looking install.
Do you plan on going with the home integration system?
If not, what’s the advantage of a hefty 100 amp (80amp cont.) installation and the Pro Power‘s hefty CCS plug ?
PJnc284
Garner, NC
Overkill for a 24 since they max out at 48 amps but likely wasn't much cost difference for such a short run.
I think the MoCo has a huge warehouse filled with FCSP's they're trying to unload, for the majority of new truck installations a derated 48 operation on a 60 wire/breaker circuit is good and cost effective install, though this is installed with maximum capacity when older Lightning friends drop in for a charge LOL
gbuydos
gbuydos
Central Iowa
F150 Lightening Flash '24
No just use as a charger. This setup is what contractor installed.
HOTAS
Airbus Pilot
The unfortunate disadvantage is that EVSE can never be used to charge any other EV/PHEV with the very common J1772 (only) or NACS port.
Just seems like the CCS plug would be less than ideal, if not DC fast charging or DC back feeding.
I wonder if a CCS to NACS adapter would allow a Tesla to Level 2 charge off that plug ?
That would be quite the contraption to plug in!
123XYZ
SF Bay Area
2023 F-150 Lightning Pro
Commend your electrician for clean work.
Be patient with the configuration process......
I'd commend him for clear labeling. I wish anything in my house were labeled that clearly. Heck, I'd be happy if they'd just labeled the breakers that are no longer connected to anything.
